Question about JBL GT120 Car Subwoofer
Want to know if its compatible
Can i run 2 jbl gt120 subs to a kicker kx-250.2
  • bruklunzfine May 27, 2009
    first off, thank you for responding. This is my first time and I really did'nt expect to get a reply so quickly. Alright, your saying that it is ok to connect them, but is it wise to. Should I invest money into a diff amp instead of taking the chance and heating up the speakers?
  • 54 Answers
Yes you can but make sure you keep the gain about 50 percent to make sure you have minimal distortion and your speakers dont heat up when pumping them to the max
Posted on May 27, 2009
BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
May 13, 2010 | JBL BP1200.1 Car Audio Amplifier
I have a JBL GTO 1201.1 mono amp and I have a kicker L5 solo baric with dual 2 ohm coils how do I run it to get the full power out of my amp?
You will not be able to get the full power from the amp without ruining your sub. The amp puts out full power into a 2 ohm load so option -A- is to just run one coil off the sub and it will absolutely pound -until you roast the coil.Then you can use the other coil and roast that one too. But since you do not want to roast anything-first thing to do is take it to the store and trade it in for a dual 4 ohm sub-wire the coils in parallel and there's your 2 ohm load to achieve max power from the amp. Problem there is that you will have WAY too much power for the sub to handle and you'll blow it anyways (in time).Best thing you can do is get an identical sub(dual 2-ohm) wire the coils in series which will make them 4 ohms per sub then parallel the subs to get back down to 2 ohms overall-you get max power from the amp and hopefully enough speaker to handle it.Hope that helps.
Feb 13, 2010 | JBL GTO 1201.1II Subwoofer Mono Amp Car...
Busted Kicker Subs
hi not worth fixing as labor is to high.
look around on ebay make sure you replace them with a name brand some companies like JBL sell refurbished subs with full warranties for cheap.
Remember with subs you must have a crossover either electronic or just a component in the cabinet so that the speaker is only reproducing the correct frequencies.
Lastly 12" subs require a ton of clean power 200 watts per ch minimum..and if possible they should be either 1 channel amps or bridged to 1 channel meaning for a pair of 12's you would have 2 amps
Contrary to popular belief most subs are damaged because people overdrive their amps and that blows the voice coil
hope that helps
Jan 24, 2010 | Car Audio & Video
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Jbl&kicker
no , I believe that you will be ok. I have a lot of experience with car stereo, and thru trial and error I''ve learned what will work and can be paired
May 27, 2009 | JBL GT120 Car Subwoofer
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Feb 01, 2009 | Kicker 02S10L74 Car Subwoofer
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
JBL GT120 Car Subwoofer Logo
69 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
