Question about Cowon System iAUDIO X5 MP3 Player
My ipod has a record control, and I can't record anymore. It appears to be stuck
I cannot record anymore. That control appears to be stuck.
    Sniper:
  • 73 Answers
Dear, there is button for record, it is not functioning properly because it is not doing the right job, if you will try to fix it, there are great chances of future damage, because of the mini-circuit in this technology. I suggest you to visit repair shop for assistance, it would be better than fixing it yourself.
Best regards.
Posted on May 27, 2009
Ipods that do not turn on anymore
When you put them on a charger does anything appear? If not the batteries are most probably dead. You could try placing on charge over night and then hold down the lock button and the front round button at the same time until you see the apple logo appear.
Nov 04, 2013 | Audio Players & Recorders
Ipod Touch wont turn on
Your iPod has been working fine and all of a sudden it won't turn on. Not sure why? Before you rush to your nearest Apple store, try these easy-to-use, at-home solutions for fixing your iPod.
Check the Hold switch to see if it is off. Located on the top or the bottom of the iPod, when it is in the "on" position you will see an orange patch of color. Slide the switch until the orange coloring disappears. Try to turn on the iPod. Make sure the battery is fully charged by connecting your iPod to your computer's built-in FireWire or USB port or into an electrical outlet using your Apple iPod power adapter. Note: iPods without a click wheel cannot be charged using a USB port. After your battery is fully charged, try to turn on the iPod. Reset your iPod. iPod Shuffle: Disconnect iPod Shuffle from the computer if connected. Move the power switch to the off position. Wait five seconds. Move the switch to the play in order or the shuffle position. iPod Touch: Press and hold the Sleep/Wake and Home buttons together for at least 10 seconds until the Apple logo appears. iPod Nano (all generations), iPod Classic, iPod Mini: Turn the Hold switch on and off. Press and hold the Menu and Select buttons at the same time until the Apple logo appears, making sure to not touch any part of the click wheel. This should take about six to eight seconds and may need to be repeated. If your iPod still won't turn on, check the following: Make sure the iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard and iPod, and try again. Double check that you are using the FireWire or USB cable that came with your iPod, and that it is in good condition. Try the built-in port of a different computer.
iPod won't turn on
http://support.apple.com/kb/ts1383
Mar 01, 2013 | Apple iPod touch
Hi my ipod video 30 gb wont play music anymore just gets stuck at 0.00 i tried restoring and restarting it but nothing worked
Have you tried this with the device unplugged?
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Mar 15, 2011 | Apple iPod MA446LL/A MP3 Player
How do i delete vidios on ipod nano?
Select the video then press and hold the center button until the options appear. Choose Delete then press the center button.
If you want to transfer the recorded video or music from iPod Nano to computer, this step by step guide would help you a lot.
http://www.ipod-transfer-copy.com/how-to-transfer-ipod-recorded-video-to-computer.html
Hope it helps. Contact me if you have any other question.
Feb 01, 2010 | Apple Audio Players & Recorders
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Sade face
The reason a sad face appears is because the hard drive is not being read for what ever reason. Unfortunatly 90% or so need the hard drive replaced. Try these first, with the face down, try to start up the ipod while tapping on the back. A hard drive is designed exatly like an record player and sometimes the arm gets stuck. Also a soft reset (Menu and Middle button at the same time for about five seconds) can often jiggle the arm free. I have also seen low battery's cause sad faces but you would need a wall charger to test this and you would have seen signs of a low battery. Hope this helps.
Aug 29, 2008 | Apple iPod MA446LL/A MP3 Player
1st Gen. Ipod Nano wheel control wont work
Greetings,
For instructions too long to post in here - click on this link
fxnlogo_s.png Technical Support, Instructions & Repair Service
Aug 01, 2008 | Apple iPod MP3 Player
IPod Nano Problem!!!
I dont need help anymore I read someone elses problem and the coment to that.
May 23, 2008 | Apple iPod nano
Cowon System iAUDIO X5 MP3 Player Logo
75 people viewed this question
Top Cowon System Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
