Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
No clean tone - no volume
I can't get a clean tone and there is very little volume on the drive channel. I can still get some reverb but little. The tubes are all plugged in and they all appear to be working but whether they are working correctly I don't know. I don't use the drive channel so its like not having an amp!!
    Problem Solver:
  • 9 Answers
First thing I'd check is if the valves / tubes are plugged in properly (it doesn't take much to loosen them) Unplug the amp then take out all of the valves and put them back in again.
If that doesn't work, try swapping the preamp valves (the little ones) around (let them cool down first) that'll tell you if one of them is worn.
Failing that I'd try cleaning the gain and volume pots with some switch cleaner, and if that didn't work I'd bite the bullet and buy a new set of valves.
Hope that helps
Posted on May 28, 2009
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the...
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Mar 18, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a Fender 2x12 Hot Rod Deville. The clean channel seems to be working fine but the overdrive channel is not. I have to turn it up all the way in oder to get just a little bit of sound. So that...
For the Drive channel you need to use the Drive control AND the MASTER volume control. When the Drive channel is active, the Channel Indicator lamp should be RED indicating the Drive Channel is active. The Drive control knob is used to adjust the preamp volume and distortion level of the Drive Channel. This gives you a clue as to what to check if adjusting the controls doesn't work -- the preamp tubes. Having said that, ONLY try to check these tubes with the amp OFF! Never stick your hand up into the chassis of a live amp. It could be lethal. Your preamp tubes are the ones farthest from where the power cord enters the chassis. They have a rubber like stabilizer on them. They have a tendency to wiggle loose, which is part of the reason for the stabilizer. Again, if you're not familiar with the insides...stay out and get an amp tech to help you.
The Normal Channel only uses the Volume Control to adjust volume.
Feb 01, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Amp is little used and now the reverb is not working. It is never moved from the room where I play.
There are only TWO op-amps and the tank involved with the reverb. Both of those are in one IC chip labeled "U2". It is a TL072.
Pin 1 of that chip is the output to the tank and pin 7 is the inout of the reverb control pot that then goes into the power amp.
They resistively mix the delayed reverb signal with the straight signal at the input of the power amp.
I assume you have turned up the reverb control which is just a volume control for the signal going through the tank.
There are so few parts involved with this that a failure is really rare.
May 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My fender hotrod deluxe still produces some sound with the volume at 0, no sound at about 1.5, then regular volume control on up. I know the clean channel sounded better before this problem started. I've...
There are FOUR controls that affect the volume of signals going through plus the tone controlling ones.
and your
You used the word "volume". Based on the schematic, and assuming you are talking about the control labeled "Volume" and not reverb, master or drive, I can give some hints.
OFTEN the resistance element in pots MAY have a bit of overtravel which can act like your unit, but USUALLY not as far upscale as yours appears..
If the control you are refering to is not the "Volume" but one of the others, then there are other things to look at.
The action you describe would be one of probablly an inverse signal leaking through and when you go up to 1.5 you are actually cancelling the leakage.
I SUSPECT you may have a cracked circuit board in the vicinity of the input jacks that is leaking the inverse phase of the input past the input triode tube stage.
Board cracks OFTEN occur near input jacks because people trip over cords... (save yourself by running cord through a handle before plugging in the plug)
This should be easy to find. Connect an audio generator to the input and use a scope to find the problem. Without a scope, use a capacitor to "ground out" suspected signal paths.
On the schematic they show a resistor (10 ohms) from ground near the input to the pot bracket. I have personally SEEN capacitive coupling to pot brackets feeding into the amps from this source sending in stray signals.
If this is connected to other equipment, a ground loop could cause problem, so test with nothing but the guitar connected.
Apr 30, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My Fender Blues Deville 212 has a very "ratty" tone on clean...
i am guessing on what the problem is , the post is very vague. i am guessing a channel switching issue. you need to check the "sugar cube" looking power resistors solder welds. they are probably cracked and arent making good contact. if you tap on the amp it will cut in and out, its probably these two resistors. they are usually 470ohm 5 watt cement resistors. what happens is they get real hot, and as they cool down they crack the little solder welds. i usually replace them with new and keep them floating up over the pcb to help them stay cool and off of the board to prevent further solder weld cracking, stock they are real close to the board. then put a little silicon under the resistor to hold it in place and to keep it still on the board. i just fixed a blues deluxe with this issue. while you are in there, cut out the resistor sitting right behind the reverb pot, this will make the reverb awesome. also solder the mid pot center leg to the mid pot leg that comes off of the bass pot leg to get better midrange control. very easy mods. check the master volume pot, is it a B100K? pull it and put an A250k in its place for better volume control. bias pots , etc. check my website yostamplifier.com.
Mar 05, 2010 | Fender Hot Rod Deluxe Guitar Combo...
EQ THEORY
There is no basis for that theory.
Feb 08, 2010 | Ibanez Ts808 Vintage Tube Screamer Reissue
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
203 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
