Question about HP Pavilion dv9000z Notebook
Blank screen on laptop
I have an HP 9000dv laptop one day works fine, next day it boots up but nothing not even a blip on the screen, I have had the harddrive and all checked said to be fine. help please
  • HP Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 27, 2009
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
Screen is blank how do I get it to work again
Do you need the external monitor to switch it back to internal monitor or both on?
Feb 07, 2012 | Lenovo 3000 G530 PC Notebook
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Hp pavilion dv6810us -- the screen went blank suddenly (no hint of a problem) and can't get it back to normal. I've forced shut off and turned back on (4 times over two days)...still black screen. All...
if it was the video card ...it will appear something on screen like Bios...when accessed..and affect only the installation ...I suspect the lcd connection
so...assuming is nothing inside...take a look on this tutorial
http://www.laptop-repair.info/laptop_screen_repair.html
Nov 09, 2009 | HP Pavilion dv6810US Notebook
Hp pavillion hdmi output was working fine and not the tv is dark. It shows a picture when booting up but once booted, the tv goes blank. Can you offer any solutions?
I had the same problem. The first time I used the HDMI port, it showed up perfectly on my TV.
But, next day I get a blank screen. When I rebooted the laptop it would show the windows splash screen and go blank.
I won't tell you how many things I tried that didn't work.
What you have to do is stupidly simple. Right click on the ATI logo in the systray, and then left click on catalyst control center. Run the basic wizard. I'm not sure which screen it is on but choose "clone". Suddenly, a miracle happens, and it works.
I don't know what kind of genius decided to make a second display not work at all unless you ran a wizard. But thats what I did to fix it.
Jul 07, 2009 | HP Pavilion dv7-1130us laptop
Acer Aspire 5052 nothing on LCD
If the LCD display worked until the processor over heated and then went blank, and would work again once it cooled down, then yes I do. As you described above, the screen going blank and blank still on reboot ( no time to cool down ), then the next day the LCD displayed again ( cooled down over night ). Appears to be directly related to the over heating problem.
But if the display problem progressed to the point that the PC would boot up cold and the display was still blank, then I would think your graphics card will need repair.
Apr 20, 2009 | Acer Computers & Internet
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Video display blinks or system freezes
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | IBM ThinkPad R32 2658 Notebook
HP Pavilion dv9000z Notebook Logo
201 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
