Question about LG CHOCOLATE VX8500 Cellular Phone
I BROKE MY SCRREEN IN THE INSIDE BUT OUTSIDE PART IS OK!
I was outside. i did not see my phone and ran it over. now when i turn the phone on the colors are all spladered on the phone. P.S. i only weigh 110 pounds. what is the problem??? i need to fix my chocolate phone!!! NOW!
I think that is some funny @^$% you should call the V store and tell them all about it. The 110 lbs. thing is great evidence for your case! go getem girl.
sz
Posted on May 31, 2009
    Problem Solver:
  • 6 Answers
Well, I have the chocolate as well. This happened to me when i fell with my phone in my hand. Well there is no immediate solution for the problem. Go to the nearest Verizon Wireless store, or call them up and they will ship you a new one. Hope I helped.
Posted on May 29, 2009
Trying to hook tv up outside of house ran cable from box in my house wont run my tv outside can I buy hdmi ******* and have it work ? Thanks
I'm hoping you hooked the cable you ran for the outside tv to the output of the cable box and didn't make the mistake of splitting the cable that comes into the satellite box. If you take the cable that goes to your TV inside you should be able to put a splitter in it and run the TV inside as well as the one outside. If it is a long distance to the outside TV you may want to buy a powered splitter that amplifies the signal. You should also be using RG6 coaxial cable to cut down on lose.
Sep 22, 2014 | Audiovox Directv Rca Drd430rg Receiver...
1996 Chevy Silverado inside and outside handles to open broke. How do i open it
Only way is to get a coat hanger and make a small hook on one end and try to slide it between the window and door panel and try to hook the door latch from inside the door.
Jan 26, 2013 | 1996 Chevrolet C/K 2500
Power button completely broke off,alternate power on suggestions
hi there is no alternate solution. you can fix it by contacting the your mobile servicer. they will change te power button.you can solve it by changing the power button
thank you
Dec 16, 2010 | Nokia 5310 Cellular Phone
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
The inside panel of my envy2 is black but the buttons still make noise/seem to work. I can't really afford to get a new one right this minute. HOWEVER, the outside panel works but I can't delete my text...
you can turn your auto erase on.open the phone hit the message button twice. press number 2. arrow down twice to prompt and it ok. I think this might work. i didn't try it though.
Mar 20, 2009 | LG enV VX9900 Cellular Phone
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Blank screen
Same thing happened to me. Mine was covered under the 1 year warranty and was replaced.
Nov 13, 2007 | Motorola Mobility RAZR V3
My display outside and inside isnt working for my motorola razr v3
bring it to a technician, and let him know what the new battery and charger did to your normally fine phone. They should be responsible for repairing your phone. No easy fix as described above. Let me know how it works.
Cynthia Charczenko
Nov 04, 2007 | Motorola Mobility RAZR V3
LG CHOCOLATE VX8500 Cellular Phone Logo
51 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
