Question about RCA D52W19 52" Rear Projection Television
BIG SCREEN rca d53w19, where are the fuses????
HAD AN ELECTRICIAL SURGE AND MY TV WENT OUT. IS THERE A FUSE IN THE BACK THAT CAN BE REPLACED, OR CAN IT BE FIXED AT ALL? where are the fuses on RCA d52w19 ?
  • RCA Master
  • 8,617 Answers
There is one fuse if you look in the rear of the set on the left side follow the power cord as the cord plugs into the Main filter board which has the fuse. Its located right next to the power cord on the right side of that board
Posted on May 27, 2009
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
FL231 Concergenc Fuse blowing
Check the ballast. Also make sure that it is plugged into a GROUNDED surge protector!
Jan 06, 2009 | RCA D52W23 52" HDTV CRT TV
BIG SCREEN
Does the set fornt led blink when you plug it in or it completly dead
Oct 28, 2008 | RCA D52W19 52" Rear Projection Television
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
Power surge
Change the horizontal output transistor if you know where it is. keever
Jan 02, 2008 | RCA 27V520T 27" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
125 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
