Question about Philips 43PP9202 43" Rear Projection Television
Phillips HDTV will not turn on I have a 3 year old Phillips 51PP9100D/37 TV that worked gret up until a week ago.After being turned on for a short peroid of time it just shut off.I have no pic. or sou
I have a 3 year old Phillips 51PP9100D/37 TV that worked gret up until a week ago.After being turned on for a short peroid of time it just shut off.I have no pic. or sound.I tried another power source.Now the power button is flashing a two code? Can someone please help me? Thanks
  • 110 Answers
Check fuse #1003 on SSB and Audio Ouput IC #7700.
Posted on May 27, 2009
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
I have a Polaroid 37" LCD TV (FLM3732)
it could be 2 caps on the power board, i had the same problem and for $3.39 at Radio Shack solved it.
There is a link on hre with pictures and instructions from stiv0, that works. Of course your on your own if you try it.
Sep 30, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Problem
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
My phillips flat tv won't turn on?
I have come accross a lot of complaints regarding philips tv's, with premature failures the common ailment. I have filed a complaint at the following:
http://www.consumeraffairs.com/class_actions/
Click the "complaint button" and fill out the form. If enough complaints are filed, an attorney will review them.
Apr 15, 2008 | Insignia 42" LCD Flat-Panel HDTV
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
629 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
