Question about Polaroid FLM-1512 15 in. LCD Television
I bought a Polaroid HDTV 1512 in 2006andit has been working fine, until recently The control has gone bonkers. Any button I push turns mute on or off, but nothing else. I changed the batteries, same results.
  • 3,741 Answers
The internal circuit of remote is gone faulty.the remote needs replacement.as this is a clear short circuit.this happens when  1)the remote comes in contact with water. 2)any of the remote button is kept pressed continuously. 3)if the moisture is got collected on the internal circuit ,due to humidity .and at that time if you operate the remote the circuit gets short due to moisture collected on the circuit. 4)if the remote falls down or get hard banged down to a wall.the circuitr gets cracked. 5)the internal touch pad gets loose. 6)the main cause the battery is faulty.but in your case the battery is replaced. but before going to get a new remote.i would suggest you to .try this 1)for 5 to 10 minutes press all the buttons randomly on the remote control non stop.facing the remote towards the tv and keeping the tv on.keep pressing all the button and check out. 2)open the remote with the help of screw driver and a thin knife which will be required.after it gets opened.in you will see a circuit board.cleran that circuit board with the isoprophyll alcohol with the help of tissue.clean both the sides of the circuit.the top aswell as bottom,the front as well as back.takr good amout of isoprophyll liquid to clean. you can get the isoprophyll at any medical shop. if after cleaning it does not start.then replace the remote as it cannot be repaired.its time for new remote. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 27, 2009
Aspect ratio selection
On your remote control there is a button that controls the aspect ratio on you television. Push the button to change the aspect until you get to the desired ratio.
May 21, 2014 | Polaroid 22" Class 1080p 60hz LED LCD HDTV...
I have a polaroid flm-3201 HDTV. It is stuck in dvi mode. I tried new remotes and pushing the side buttons but it doesn't do anything. Not even the volume controls work.
WHAT YOU NEED TO DO IS TAKE IT BACK TO THE STORE YOU GOT IT FROM BECAUSE THE ONE YOU HAVE HAS A MANUFACTOR DEFECT ...
ANY STORE YOU GOT IT FROM SHOULD EXCHANGE IT IF IT WAS BOUGHT WITHIN 60 OR 90 DAYS FROM PURCHESS DATE //
HOPE THIS HELPS =)
Nov 18, 2010 | Polaroid FLM-3201 Television
Polaroid camera t1455 will not turn on. Charged battery & inserted & nothing happens.
The screen on my Polaroid has gone blank, I recently bought it from www.justdeals.com, I got it for a good price but now its not working, has anyone had a similar problem and knows the solution?
Nov 08, 2010 | Polaroid Cameras
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Directv remote won't turn on tv or control volume
I am a installer and 10154 works wth every Sanyo TV whether it is HDTV or a SDTV that I have encountered. Try this code using same method above but do not enter 911 but rather 10154. It should work!
Apr 02, 2009 | Directv RC23 Remote Control
I bought my Polaroid 373-B without a remote. I then bought a RCA universial remote that has worked until it dropped the codes. Now, I can't find the list of codes to re-program the remote. Can someone help...
Hi stevieb44, I am happy to help. Turn your TV on.
  1. Press and hold the TV button
  2. While holding the TV button press and hold the Power(on/off) button, the light will go out and then come back on.
  3. Release both buttons, the light should remain on.
  4. Point the remote at the TV.
  5. Press the power button repeatedly until TV turns off, wait about 5 seconds between pushes.
  6. When TV turns off press the Stop button at bottom of remote, that will lock in the code.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Oct 18, 2008 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Polaroid FLM-1512 15 in. LCD Television Logo
41 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
