Question about Philips 43P8341 43" Rear Projection Television
Philips 43P8341 picture bowed red wont line up
Just got this from a friend its a Philips 43P8341 the picture had been bowed on all the sides and also the picture is kinda big for the screen. then about a month ago the red went out of wack. from what i have read its a convergence problem. is this right? and if so where can i get the parts and what are the part number to be sure i order the right stuff
  • Philips Master
  • 8,617 Answers
You will need two STK392-120 convergence IC and about six 6.8 ohm 1watt convergence resistors you can get the parts at the following link and they provide free step by step instructions with pics.
http://servicemanuals.vstore.ca/
Posted on May 27, 2009
Philips 43p8341/37, The menu does not appear on the screen when selected by either the remote or the unit, also the picture is bowed at the top and the bottom of the screen making the center of the...
The board you will be working on is the signal module. The signal module is the board on the floor of the TV. When you locate the RCA connections and the RF connectors on the back of the TV, you will know that you are where you should be. You will see two large silver fins, these fins are heat sinks and two ICs are attached to them. They will be STK-392-110, and both will need replaced. Also check and measure the 6.8 ohm 2 watt resistors next to these ICs just mentioned. Should be ten or eleven resistors. Replace as necessary. The next problem you describe is a halo effect on the screen and no menu on screen. You will need to replace contaminated fluid in one of the picture tubes. You will find three picture tubes, lit, they are red, green, and blue. I would suspect the blue has the contaminated fluid. You may look in the tubes and decide which one is cloudy. For more detailed instructions and photos, I would suggest you see the website, www.TvRepairKits.com. H ave your TV model number and symptoms near by. You can purchase a kit or kits to restore your TV. The instructions are very detailed along with photos as how to repair. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 43P8341 43" Rear Projection...
Picture display
The digital convergance is going.In Canada it's a $450 repair which is not worth it
Sep 28, 2009 | Philips 43P8341 43" Rear Projection...
Philips 43P8341 will not turn on
sounds like your two convergence ICs are shorted out, plus you probably need two 6.8ohm resistors ICs are part # STK392-120
should be installed by a trained repairman cost about $300-400
Aug 17, 2009 | Philips 43P8341 43" Rear Projection...
Red convergance
You will need to replace both convergence ICs they are STK392-110 and you will also need four 6.8 ohm 1watt resistor. You can get replacement ICs and resistors at the following link with free installation instructions.
Sep 21, 2008 | Philips 43P8341 43" Rear Projection...
Phillips 43P8341 no picture, blinking red light
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
May 17, 2008 | Philips 43P8341 43" Rear Projection...
PHILIPS 43P8341 CONVERGENCE OF GREEN AND RED
Look for the STK ICs mounted on 2 big heatsinks.
I would suggest to replace both of them once you have the TV taken apart.
I think the part markings are STK392-040.
Let me know if you need further assistance.
Apr 29, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 43P8341/37 blue color problems
Change the coolant in the blue CRT and your picture will be new looking again. Let me know if you need more information.
Mar 15, 2008 | Philips 43P8341 43" Rear Projection...
43P8341/37 tv is acting up
Generally, a convergence issue...requires chassis pull &
replacement of two IC's.....large STK's on largest heatsinks in set......up-grade for STK392-110,120 = STK393-160...I use
Hitachi # CZ 01341.....Do not use generics ! Also,check for
over-heated resistors near IC's....1 to 2 ohm.....1 to 2 watt.........
........................T.
Feb 09, 2008 | Philips 43P8341 43" Rear Projection...
Philips 43p8341
this may need a small signal module and or stk packs
Dec 06, 2006 | Philips 43P8341 43" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
217 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
