Question about Vizio GV42L 42 in. LCD Television
Sparking sound coming from television
Just yesterday I began to hear a "spark" or "electrical arcing" sound coming from the television. I unplugged the soundbar and no longer heard the sound. Is this a problem with my sound bar or is it an electrical static issue within the television that is picked up by the speakers?
2 Suggested Answers
hichbiri
  • 3462 Answers
SOURCE: I HAVE VIZIO E28h-C1 TV AND ALSO VIZIO SOUNDBAR MODEL SB3851-CO BUT DOES NOT HAVE THE HDMI ARC OUTPUT AND THE TV DOES HAVE IT HOW CAN I USE HDMI ARC ON MY SOUNDBAR. PLEASE HELP ME . THANK YOU
obtain an adaptor through radioshack in the US or Maplin in the UK
Posted on Jun 13, 2015
Hyundai accent problems
some tweeters have noise coming just like electric arc. I had the same issue in my suzuki alto whenever I honk. Just check if it is from tweeters.
Jan 12, 2014 | Cars & Trucks
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
1) Right rear burner electric spark always arcs no matter which of the four gas knobs I turn. 2) Right front burner electric spark only works (arcs) when left two burners panel is unplugged or removed.
Sure. Once we realized that you'd charge a fee, we went to our local brick and mortar appliance repair store and got the info needed for free. What happened to free advice?
M
Dec 02, 2008 | Amana Kitchen Ranges
Sparking Sounds and the picture jumps momentarily.
You need to remove the back and observe where the spark is coming from while the set is on. Dimming the lights may help you. Sometimes you can see a blue glare accompanied by an ozone smell. You might even hear a sound such as a slow air leak in a tire. The most likely area is around the high voltage transformer or the picture tube anode. The transformer has the thick red wire or wires coming out of the top. Also follow the three red wires to the picture tube anode( the place where the red wire plugs into the tube) Use your senses, listen smell , and look for any blue glare or arcing to the metal frame. If you find the leak near or on the transformer use 100% silicone rubber to patch. Allow at least 12 hours to cure. If the arcing is coming from the picture tube contact me for detailed instructions. You must act promptly and find the source of the arcing before you have a dead set. In short, spark + flash = crash. Good luck
Nov 13, 2007 | JVC AV-48WP30 48" Rear Projection...
Rca tv electrical problem
Hi, If the TV is still operational, what you are hearing are probably high voltage arcing. Most common are in the anode cap area brought about by accumulated dust, grime and dirt on the outer glass envelope of the picture tube. This occurs mostly after a continuous or heavy rain or when the surrounding air is damp. Since the unit is still operational except for the "sparks", this should only require cleaning of the above stated area. However, there are extremely high voltages even when the unit is off that perhaps you are better off seeking the services of a qualified TV technician. Other possible areas of arcing are the fly back transformer, the horizontal output transistor PCB soldering points, the G2, Focus solder points. in some remote cases, it can be just inside the neck of the PIX tube. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Televison & Video
Sparking/growling NEW microwave
Don't use it! Unplug it and take it back to the dealer-sounds like a loose wire or short.
Jun 24, 2007 | Westpoint TV-201 Microwave Oven
RCA PROBLEMS
two common problems with RCA TV's. It sounds like your flyback is going on you. There is probably a hole and it is arcing off a cap/ or something. You can order a new one or you can try and find where it is arcing by taking the back and looking at it in the dark to see where the arc is coming from. If you can find it try using a plastic epoxy to fill the hole
Apr 13, 2007 | RCA F32649 32" TV
Poping sound, white specks and what looks like sparks
Possible arcing CRT or possible arcing IHVT part # 239111.
Dec 29, 2006 | Proscan PS50700 50" Rear Projection...
Vizio GV42L 42 in. LCD Television Logo
78 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
