Yes, you could have hook the light wire to a ground. Light wires are usually a dark brown. Not hard to get them mixed up, with low or no lighting when you installed the radio.
You need to make sure the yellow wire is going to a constant power source. That is a source that still has 12v going to it when the key is turned off. The yellow wire controls the memory for the clock and preset stations.
U NEED TO OVER HEAT UR XBOX 360 BUY STOPPIN THE FANS WEN U BOOT UR CONSOLE UP IT WILL TAKE ABA 2 MINS IF THAT TO OVER HEAT IT WILL INDACATE ON THE RINGS WEN ITS OVERHEATD IT WILL SHOW TWO LIGHTS ON THE LEFT THE TURN XBOX OFF WAIT FOR IT TO COOL DOWN TO ROOM TEMP THEN TURN ON AND PLAY
Ive got the radio problem, having to remove the radio fuse each time I get out of the car - its the blue 15amp on the top row of the fuse board. As for fixing it, heard its either down to the radio switch or diode? Taking mine to garage though.
Sounds like you may have burned a part of the wiring loom! or some units have in-line fuses to protect againt current surges, turn the radio over and look for fuses on the back. perhaps there are in-line fuses behind the radio in the loom!
you can only start the car starter three time before pcm disables the function must start agin with key to get working. also may have diabled car starter by dic comands on radio also if you have engine light on will not operate car starter due to light.
wen i turn on my mp4 (COBY) it only shows a white screen but i cant lissen to music or nuttin b.c it doesnt show the list.....wen i turn it on iyt juss has a white blank screen how can i fix this.....THANK YOU VERY MUCH
