Question about HP Officejet Pro L7680 All-In-One Printer
Printing in Mirror image
I am using a HP L7590 and when I print a report from Pastel (accounting System) it prints in a mirror image. This has only just started happening in the last week If I print to a different printer it prints correctly.
  • HP Master
  • 419 Answers
It's likely that you have an old outdated printer driver for your L7590 as this has been a long "known" issue with the L7000 series of MFD's.
To resolve the issue properly you need to uninstall the current driver version and then download the latest version of the software that isn't just driver/basic based.
You can extract the source files including the drivers folder using 7zip if you want to try and avoid installing all the additional bloat that comes with these printers.
Failing that, you need to define alternative quick settings to take over from duplex (two-sided) printing as this appears to have been incorrectly set to use mirror printing. Other quick settings have been implicated as well but the driver update should resolve all of them.
In some instances the driver update doesn't apply properly so you may need to uninstall and reinstall more than once... Remember to delete your printer from the printer listings and unplug it from the USB cable before you uninstall and reinstall to get it to work properly.
Hope this helps.
Martin
Posted on May 28, 2009
I have an HP that does the same thing. Mine is the Officejet Pro l7650 - which I hate, btw. I think it started when I changed a setting when doing photos. Since then it is hard to get the MIRROR image off permanently BUT if you go into PRINT PROPERTIES, PRINTING SHORTCUTS ( select one ), ADVANCED, and change the MIRROR IMAGE to OFF, the click OK - it will at least print properly for a while. That setting should hold but it continually reverts back to MIRROR IMAGE "ON" when you reboot your computer OR change to another shortcut option.
I would recommend reinstalling the software to solve the problem permanently, as I think that is the long term solution.
I plan on doing the same.
Posted on Nov 25, 2009
I have HP Office Jet L7680 All-in-one printer, for unknown reason it keeps printing the "mirror image" of a document I'm trying to print
Try this...
Go to <Start> <Printers> Right click on your printer and select properties. On the "advanced" tab uncheck "Print Mirror Image". I know the path works for other printers, but I can't validate it for you that model.
Source: http://h30434.www3.hp.com/t5/Other-printing-questions/Printing-in-mirror-image/m-p/19203/highlight/true#M1817
I am an HP employee. I do not represent HP on this site.
Aug 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
Oct 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
Mirror image printing
When you first click on print a window opens with boxes at the bottom. If you choose printing preferences another box will open where you can turn off mirror image printing.
Jul 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Apr 21, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
L7590 printing right to left
Dina, I'm posting this as a solution so you may rate it as Fixya:
Is this a mirror image you are getting?
If so, open a document, select Print.
When the Print window opens select Preferences or Properties (whichever yours has). Click on the Advanced tab and look for a Mirror Image option. If it says ON, click on it and it will change to a drop down menu. Select Off.
As for the faxing...There is not much that can be done except perhaps check the resolution you are sending faxes at. The higher the resolution the longer it will take to send.
W
Jan 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7590
I hit print on the pdf file, went to properties and THAT was still set to mirror, so I changed it and everything was o.k.
Sep 25, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
227 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
