Question about Mackie 1604 Vlz3 16 Channel Mixer
I have a mackie 32.8
I have problem with all my auxilier control none are working and have have a buzz sound. thanks
  • 73 Answers
Hi there. Disconnect all auxiliary inputs. Still buzzing? Internal problem. Not buzzing? External problem.
Thanks
Paul
Posted on Jul 11, 2009
Hi , Do you have a full schematic for Mackie 32.8 mixer ?
http://www.mackie.com/products/32-8bus/#DOCUMENTS will have an owners manual- it has a block diagram in the last chapter.
Sep 18, 2014 | Music
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Feb 21, 2012 | Music
Buzz sound
You've made a statement, please give full information if you would like help. Is the buzz heard from the speakers or the mixer? Do you get normal sound too? Is it there with no input? Does it change with the output setting? Help yourself to get help and let us know properly what's going on.
Jul 19, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Hi. I have a Mackie onyx 1640i. 2 days ago it was working, but now the computer sees only 2 output channels. There was no shock, etc... Thx
Check the settings in your computer in the control panel "sounds and devices" under the "Voice" and "Audio" tabs. Check that all are set to the Mackie instead of the computers default input.
Jun 08, 2011 | Mackie Onyx 1640i Mixer
Problem with Mackie SRM450V2: HFsignal bleeding through LF driver,low HF OUTPUT also. Filter problem i suspect.
There is an entire crossover circuit inside that is BEFORE the amp section. There are 2 separate amps: one for HF and one for LF. Can you describe the noise you are hearing in more detail? Is hte sound effected by the gain controls at all? What happens without any input?
Thanks,
Dan
Feb 10, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
I have mackie mr8's my left one, when powered on makes a loud buzzing sound...i have disconnected power and pre amo...reconnected and it still happens...whats wrong?
Sounds like a ground loop. MAKE SURE ALL of your equipment is fed from the SAME receptacle. Make sure the ground pin on the power cable is good (try another cord or swap). Swap the audio cable to verify the cable has a good ground.
Sep 19, 2009 | Mackie MR8 150W 8 Active Two-Way Studio...
Mackie 1604 Vlz3 16 Channel Mixer Logo
283 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
