INSTRUCTIONAL STEPS
To reset iPod touch, press and hold the
Sleep/Wake button and the
Home button at the same time until you see the Apple logo show up on the screen:
How to unfreeze or reset an iPod Classic
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Now press and hold the Menu and Select buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step.
Notes:
- If you are having problems resetting the iPod, go ahead and set it on a flat surface. Then make sure the finger pressing the Select button is not touching any part of the click wheel. Also be sure that you are pressing the Menu button towards the outside of the click wheel, not near the center.
- If the above mentioned steps do not work, then you can try connecting your iPod to a power adapter and plug the power adapter into an electrical outlet, or connect the iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
How to reset an iPod Nano (1st, 2nd, and 3rd Generation)
This one is similar to how you would do it for an iPod Classic:
1. Toggle the
Menu and
You can also reset an iPod Mini in the same way as the above steps.
How to reset or unfreeze an iPod Shuffle
1. First , eject your iPod shuffle from iTunes, if you have it connected.
2. Then remove the iPod shuffle from the USB dock.
3. Move the switch that is on the top of the iPod shuffle to the
off position.
Note: When iPod shuffle is off, the green stripe by the switch is not visible.
4. Wait 5 seconds.
5. Move the switch back to the on position so green stripe will be visible in either position.
And that's it! Hopefully, now that you know these steps, you don't have to keep taking out the battery to unfreeze your iPod! Any comments or questions, make sure to write below! Enjoy! Source: Apple Support
[tags]ipod, unfreeze ipod, reset ipod, how to unfreeze ipod, how to reset ipod, reset ipod nano, reset ipod classic, reset ipod touch[/tags]
Remember to leave your comeeent testimony and recommendation saying how helpful this tip is to you
