Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
**Please Read *** Correction - I am not having teeth problems - not sure how that got in there.
I have a craftsman LT1000. The tractor was used 2 times since last summer. I have a Craftsman LT1000 - Tractor has been great no problems for last 5-6 years however; this year It suddenly started sputering and spitting and running uneven while under load. I replaced air filter, fuel filter, spark plug - which seemed to fix the problem for about 5 minutes. Until it starting running poorly again. I checked the spark plug (not fouled) and i checked spark plug is getting blue spark. However; Now she will not start. Original Fuel Filter didn't seem blocked (unable to get a replacement - discontinued according to SEARS Hardware - but same exact stock # as brand new mower :(!) Replaced with Briggs and Stratton Standard In Line Filter. (States fit's all 1/4" and 5/16" mowers up to 80HP. Now mower will not start. tried using original fuel filter however; same result will not start. ( I am stumped on this one! Help Please I'm not a mechanic so I would appreciate some help. I also replaced the original battery with a new Everstart. Not sure if these mowers have magnetos. Anyone have any experiences with regards to fuel filters I can provide model number if needed.
-really appreciated!
  • 1 more comment
  • tomtopshelf May 27, 2009
    No, I have not. I am not a mechanic. Is this difficult? Any ideas on how much a carb kit would cost for it? and recco's on where to buy one?
    Advice is Much Appreciated
  • tomtopshelf May 28, 2009
    Ok I have Fire - blue spark coming from the plug
    Will look into cleaning the carbs - Many Thanks
  • bart braun May 11, 2010
    have you tried cleaning the carb, it may be fouled up with tarnish and is not working properly. or it may be that you need a carb kit.
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
Posted on Nov 28, 2009
Runs then stops after lawn is almost done,i wait 5 minutes and it will run again then stop,cahge plug filter new gas it still happens,could it be the muffler?
Posted on Jul 16, 2011
  • 3 Answers
How do I start cleaning my carburetor, and what is the device call that get the fuel to the carburetor?
Posted on Jun 04, 2009
  • 46 Answers
Ethonal ive read several articles on this new gas it is causing all kinds of trouble with small engines and outboards/ if you have fire it is not the magneto
Posted on May 27, 2009
  • Roy Cagle
    Roy Cagle Jun 12, 2011
    You have forgotten one very important bit of maintenance on this machine. The overhead valves have to be periodically adjusted. They work in unison with the built-in compression release to aid in starting. Poor running or very hard starting problems can be resolved by adjusting the intake and exhaust valves just behind the little metal cover stamped OHV. Briggs has the valve clearances for all their engines in a page in their site.
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
I was engaging the blade on my 17 hp craftsman lawn tractor and the engine died. Now the engine won't turn over. ???
the motor wount turn over if in fact the belt is tight around the motor pully. remove the deck belt then also make sure there are no switches not working.
Nov 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor. Runs
It doesnt sound normal.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I change the drive belt on a 17 horse Craftsman lawn tracton number 917.252531.
Page 24 of the manual:
http://www.managemylife.com/mmh/owner_manuals/23145/CRAFTSMAN-Lawn,-Tractor-L0909236?brand_name_search=917252531+CRAFTSMAN
May 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start
try replacing the relay in the middle of the ignition and starter.
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
799 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
