Question about AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor
Impeller rotates, seems to work well, o-rings appear to be OK, but pump will not draw water through the pump
Impeller rotates, all seals are tight but pump will not draw water
  • 59 Answers
This usually indicates an air leak in the plumbing. it will **** air because it is easier than water if there is a leak in the plumbing.
good luck David
Posted on May 27, 2009
  • cindyshudson
    cindyshudson Apr 05, 2013
    How would I find the leak?
  • David Lowry Apr 06, 2013
    The pump is not always the problem. Usually you are drawing air and it will not pull the water to the pump. If it is for an above ground pool, it will not pull water very far at all. If it is for an inground pool, you should check all air leaks before you check anything on the pump. If you are leaking water at the pump, then check the shaft seal.
How many impeller fit on the pump
Impellers, vary. You can't put any impeller on a motor! Things to take into consideration for proper water movement / hydraulics, is the different parts of the volute: where the tide housed. You have the:
  • Impeller
  • Diffuser
  • Wear Ring
  • Shaft Seal
  • Seal Plate
The impeller also had to match the HP! If impeller is oversized, the motor will be over worked! If impeller is under sized, then the motor will work effortlessly, but is a waste, because it should at least be at capacity. Even if within the same manufacturer, impellers vary widely. So, find the correct impeller and use it.
Mar 13, 2015 | Pool & Spa
The motor and filter seem to be ok, but can't get it to prime. Everything is working,just very little water pumping into filter.
It sounds like you have a suction leak or a clogged impeller. A quick way to check the impeller is to fill the pump pot (where the basket is) with water, then start the pump with the lid OFF. The water should be sucked down into the pump immediately. Turn the pump off. If it took more than about half a second for the water to disappear you need to open the pump and clear the debris from the impeller.
Otherwise any leak from the skimmer to the pump will cause the problem. Make sure your pump lid o-ring is lubricated.
Apr 05, 2013 | Pool & Spa
My2 hp max e pro pump runs but barely moves any water
Have you opened up the wet end? If you have pine trees near you, it is probably a blocked impeller and needs to be cleaned. If this is not the case, is the pump basket full of water or air?
If it is full of water, it is either the impeller, or the motor bearing.
if it is full of air, it is an o-ring or shaft seal. more likely the shaft seal. Always check the impeller first.
Oct 09, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Pump will not draw water in from skimmer.the pump seems to work fine except that need help?
ON A HAYWARD #1 BROKEN IMPELLER OR PLUGGED ,#2 SHAFT SEAL #3 LID SEAL #4 TANK CRACKED.. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY USE YOUR ZIP IN YOUR SEARCH .. YOU WANT THE IMPELLER WITH THE BRASS SHAFT ! ASK FOR IT HECK DEMAND IT !... YOURS IS PLASTIC = PLASTIC THREADS (JUNK) . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Hayward 3/4hp Super Pump Inground Pool...
How to disassemble a magnum 1500 - to change the bearing seal.
On the big lock ring there is a small clip that you pull out away from the ring then turn out of the way. It is just a peg to stop the ring from turning, with that done from the back of the pump loosten the ring in a counter clockwise direction. With the ring clear start the pump for just a second a couple of times till the water pressure pops the pump in two. Once that is done I beleve it has five screws holding the difuser on, pull that and on most models their is a center screw on the impeller. This screw is a left hand thread so turn it clockwise to loosten it. Then insert something flat and strong in a vain of the impeller on the left side and give it a sharp hit to start the impeller spinning off. If need be spin the rest of the way off and your at the seal. Rember when putting this back together Hand tight only on the impeller and use a teflon or silicone base lube not petroleium jelly.
Jun 25, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Blanket stuck in washer
is it under the agitator if so theres a screw inside the cap and that will usally get that agitator out
Jun 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
NOISY WHEN DRAINING ON OCCASION
This is a sign of a faulty drain pump impeller. the drive shaft that is connected to the impeller is stripping the impeller. you will eventually need to replace the entire pump soon.
Jun 06, 2009 | Fisher Paykel Eco IWL16
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Nov 02, 2008 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor Logo
338 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
