Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 17.5 LT1000 Won't Start - Need Help
I have a craftsman LT1000. The tractor was not used since last summer. I tried to start it but the batterry seemed to be dead. Replaced battery by a brand new one. The startet is truning but the teeth are notg engaging the matung teeth to start the engine. I thought I had a bad starter: got a new one & replaced it ... same problem. What else can cause this problem. I have a Craftsman LT1000 - Tractor has been great no problems for last 5-6 years however; this year It suddenly started sputering and spitting and running uneven while under load. I replaced air filter, fuel filter, spark plug - which seemed to fix the problem for about 5 minutes. Until it starting running poorly again. I checked the spark plug (not fouled) and i checked spark plug is getting blue spark. However; Now she will not start. Original Fuel Filter didn't seem blocked (unable to get a replacement - discontinued according to SEARS Hardware - but same exact stock # as brand new mower :(!) Replaced with Briggs and Stratton Standard In Line Filter. I am stumped on this one! Help Please I'm not a mechanic so I would appreciate some help. Thanks Much! Comment posted on May 27, 2009 **Please Read *** Correction - I am not having teeth problems - not sure how that got in there.
I have a craftsman LT1000. The tractor was used 2 times since last summer. I have a Craftsman LT1000 - Tractor has been great no problems for last 5-6 years however; this year It suddenly started sputering and spitting and running uneven while under load. I replaced air filter, fuel filter, spark plug - which seemed to fix the problem for about 5 minutes. Until it starting running poorly again. I checked the spark plug (not fouled) and i checked spark plug is getting blue spark. However; Now she will not start. Original Fuel Filter didn't seem blocked (unable to get a replacement - discontinued according to SEARS Hardware - but same exact stock # as brand new mower :(!) Replaced with Briggs and Stratton Standard In Line Filter. (States fit's all 1/4" and 5/16" mowers up to 80HP. Now mower will not start. tried using original fuel filter however; same result will not start. ( I am stumped on this one! Help Please I'm not a mechanic so I would appreciate some help. Thanks Much! Comment posted on May 27, 2009 I also replaced the original battery with a new Everstart. Not sure if these mowers have magnetos. Anyone have any experiences with regards to fuel filters I can provide model number if needed.
-really appreciated!
Pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
Craftsman lt1000 wont start because of gear shifter
go to sears parts direct enter model # it will show u every thing if u have a printer u can print a full manual
Mar 05, 2013 | Craftsman Garden
Need help on installing a 2 bin hard bagger on a craftsman lt1000
call sears, and ask them to get you the manual.
Nov 20, 2011 | Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
try replacing the relay in the middle of the ignition and starter.
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,237 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
