Question about Canon Cameras
I attempted to unlock a 1.0 gb camera card today which has been locked. After attempting to unlock it using a utility knife (since the lever was missing) I gave up after trying to load and reload the locked card. Then when I reinstalled the other card (same type which was unlocked and in use today. This card now is unusable with the same message showing on the camera screen. Yet another card that is also unlocked was used and the same message again. I now cannot shoot photos since all three cards are identified as locked.????
  • adaire May 27, 2009
    Still showing "card Locked" I tried each of the 2 that are unlocked and reset no change
  • 4,806 Answers
Hi there.
Turn the camera on and go into the setup menu, look down the list for "reset" and reset it, then try another camera card.
Please post back the results.
Good luck and thanks for choosing FixYa!!
Posted on May 27, 2009
How do you get card locked off
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Samsung Digimax 530 Digital Camera
Format xd card error I bought new Fugifilm xD-Picture card, 1 GB, and putit in camera. Brought up format screen and attempted to format. All I got was "card error!". I thought the problem might be the...
Try formatting the card on your pc, connect the card to a card reader, open my computer find the card, right click format, try standard fat first and format. if that doesn't work try Fat 32.
Jul 16, 2008 | Olympus Camedia C-350 Digital Camera
Unlock SanDisk 32GB Ultra Backup USB 2.0 Flash Drive
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Jun 07, 2012 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
"card protected " appears whenever i attempt a
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
If that doesn't work, try another card.
Mar 14, 2011 | Sanyo Vpc-s1070w Digital Camera
C 750 olympus is not accepting 2 gb card
According to user manjual, Olympus C750 accepts XD cards up to 256mb only, But according to info made availble by Olympus it can take up to 512 mb cards.
I have never tried my self using othre than 128 mb card, except once I tried to use 1 gb card and it reported error saying 'cannot format'.
I bleieve Olympus hasn't made attempts to make availble a firmware upgrade as the camera doesnt have ne more etramemory to accept updates.
Jan 12, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
Im attempting to use a new SD card, camera says memory card error, card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 25, 2010 | Canon PowerShot A540 Digital Camera
My sandisk 1.0 GB memory card with a lock switch on the side, no longer has the switch when i tried to unlock it the switch came off. what can i do to unlock it
1.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 2.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 1GB microSD Memory Card
When i attempt to delete pics from the camera it says card locked, how do i unlock the card
if you use an sd card on this camera you have to remove it and see that aside it has a locking device ..like a slide with 2 positions...probably yours is on locked and this protect the content and do not let you delete ...also look in the menu cause it might have a protection also ....somewhere related with the memory ...but most probably ..is the lock prom the card itself...
Nov 01, 2009 | Polaroid I533P Digital Camera
How can I change the "protected card" so that I can once again take pictures - and how can I keep this from happening again?
Pull your sd card out of the camera... there may be a lock tab along the left side of the card (label facing you and metal tabs up) the lock position is labeled... you can change it with your fingernail... make sure it's unlocked...
Let me know if you're up and running...
k
May 29, 2009 | Fuji FinePix A201 Digital Camera
Cameras Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
