Rolling picture After being powered up for about 3 hours the picture begins to roll like an old-time tv vertical hold needed to be adjusted. If I stop it and restart it there is no picture. Unplugging it (I let it cool off for a few hours) and it works ok again for a while, then same thing happens
  • ragdollfan May 27, 2009
    I unplug the vcr, not the tv.
    Sniper:
  • 73 Answers
Dear, this is problem in the circuit, you need to change the VHold you your tv, but it is not an easy job, if you don't have knowledge about fixing it, it would be better to visit the repair shop, otherwise it will affect the picture tube quality and cause further damages.
Best regards.
Posted on May 27, 2009
Lost remote ans ended up deletde ch 3 what can i do,plus thr tv is rolling picture.can this be resolved without a remote
rolling of picture can be controlled by v.hold or vertical hold on your tv. some tv has has this control on the back side. if the control is there & it is not controlling the rolling of picture, that means the control is bad & needs replacement. to get ch 3 back: go to menu & try to find SKIP function, go to ch 3 & put off SKIP.
Aug 25, 2011 | Televison & Video
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Philips 25PT2252
Vertical hold will adjust the frequency (refresh) which would remedy it if the picture was rolling. I had to open up my TV (not recommended unless you know what you're doing) and adjust a "pot" which will adjust your screen's hourglass problem. I hope this helps.
Jun 28, 2008 | Televison & Video
Tv want stop rolling i can hear sound good but the picture i cant see for it rolling in red
I will need the model number to be able to even begin to help make a suggestion as to the cause of the vertical sync problem. can you explain what you mean by rolling in red?
Jun 08, 2008 | Televison & Video
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Rolling screen
This may be a vertical hold control problem I'm not sure where the Vert. Hold potentiometer is on the mainboard. I would see if you can find someone who can locate it and adjust it.
Sep 15, 2007 | RCA HD52W56 52" Rear Projection HDTV
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
