Question about LG WM2077CW Laundry XL Front Load Stackable Washer
LG WM2077CW small item trapped behind drum
LG WM2077CW washer seems to have a screw or coin trapped behind the drum. You hear it rattling around during the spin cycle. How can I remove the item from behind the drum? Any ideas would be appreciated. Lisa
  • 56 Answers
You would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
Posted on May 27, 2009
I have an LG troll washer that is making a loot of noise from the drum. And is bouncing around. It sounds like something is rattling around exterior of drum.
Sounds like a coin, nail screw or bra wire stuck in the drum / tub cavity. It will be difficult to remove if so - try removing the water heater and looking with a torch into the hole - if something is stuck on the front lip edge of the wash drum, you may need to strip the wash tub to pieces or replace - (good luck with that!) and it will have caused damage of some sort. ALWAYS check trouser pockets before washing!!
Avoid lying the machine on its side as water from the soap drawer or sump will probably run onto the expensive electronics cards.
Feb 03, 2018 | LG Washing Machines
Clinking sound in a Siemens WFXD5200UC/01 front loading washer
I would suggest that a small thin metal item has got into the outer drum unit. This is the space between the internal spinning drum and the outer casing. This can sometimes happen by the object passing between the rubber door seal and the drum. Not easy to get out, however if it is small enough it may eventually find its way into the pump filter trap. There is a small round cover plate at the bottom right hand side of the machine. Behind the cover is the filter trap, open it up (when machine empty) and check for the object every so often. To open the filter turn the plug cover about a third anticlockwise and it should release. Pull gentle on the plug to remove from the machine.
Feb 14, 2016 | Siemens WFXD5200UC Front Load Washer
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
Repair manual
Good Afternoon Brenda - Generally speaking, washer machines do not have a filter. Depending on your particular model the unit may have a coin trap. Below are some basic troubleshooting steps you may wish to follow to locate and clean the coin trap:
  • Unplug the unit.
  • Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
  • Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
  • Clean the drum out with as much water as possible that you can remove and have towels ready. The next step you will have the remaining water come out of the bottom of the drum and onto the floor.
  • At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
  • Reach inside the coin trap and clean what is inside of it out.
  • Put the unit back together following the same steps backwards.
Hope this information proves to be helpful!
May 14, 2013 | Frigidaire GLTF2940ES Front Load Washer
Diagram to show pump filter on an affinity
Hello - After further researching it does not seem that there is an actual diagram available. However you may try the following steps to clean out the coin trap on an Affinity washer. Please be very cautious and it is actually recommended for this to be done by an actual certified technician.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Oct 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Think a coin is stuck in the drum of our front loader washer. Still rotating but can hear it rattling around. Can we still use or is there a risk of creating a bigger problem? Is there any way we can get...
yeah but its hard, and may not just fall out. Tip it on its side or front to get the panel on the bottom off. then open the bottom of the machine, and take off the black rubber hose (has a screw driven hose clip) this will allow the coin/button/bra thing/kids toy from the burger joint to fall out when you tilt the machine back and spin and jiggle it. good luck. buy a spare belt and read the belt too small posts. (its not too small!)
Oct 12, 2010 | Electrolux Washing Machines
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
Whirlpool Duet Sport Washer from Costco
remove the sump hose from the outer drum and try to fish it out with a bent piece of wire. the sump hose is usually at the bottom of the drum and after taking it off will leave a hole big enough to remove the object
Jul 24, 2008 | Washing Machines
Kenmore front loader
There's no easy way of getting something out of between the tubs without removing the rubber door seal from the tub. It's a pain in the rear to get it to go back on too, because of the retaining spring that holds it in place. Are you sure the screw is between the tubs and not stuck behind one of the was tub fins? Most small items like screws will eventually find their way into the drain line and get caught in the drain pump strainer. Since you can't see the screw, it may actually be trapped behind one of the fins. One way of knowing is to roll the inner basket with one hand and listen. If you hear something rattling around it's somewhere in or on the inner tub. The outer tub (or shell) does not move. You can also look through the inner tub holes with a flashlight while turning it slowly to see if you can see anything between the wash tub and shell. Usually, water and gravity will force anything lying in the tub shell into the drain line. Let me know if this helps you.
Jul 06, 2007 | Kenmore 43142 Front Load Washer
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
835 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
