Question about Panasonic PV-DV200 Mini DV Digital Camcorder
Udate for the photovu link and card link
I am wanting to connect my camcorder to my computer but I am using Windows XP and the floppy disc provided is for Windows 95/98.  Can someone help me with an update or a suggestion as to what I need to do to get my video on the computer?
  • laylabella Oct 22, 2007
    Thanks!  I will give it a try as soon as I can find the FIRE wire card.
    Lori
You need to install a FIRE Wire card in your computer and use the appropriate cables connect the camera.XP is capable of recognizing the card.
regards
suraweera
Posted on Oct 21, 2007
SOURCE:
Imation link troubleshooting
Connect it. Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8.
May 14, 2013 | IBM USB Portable Diskette Drive (05K9276)...
Why not provide windows xp drivers for desktops
because desktop motherboard have no standers.it is used by different type of devices depends upon the company of desktop motherboard.for example graphic card and sound card.now the newer motherboard have not providing windows xp supported drivers because the users are udating there operating systems to windows 7 this is one fact. so the companys are not providing windows xp drivers.it is outdated operating system of microsoft.
Sep 04, 2011 | Computers & Internet
I lost my CD-ROM for DCR_TRV260 sony digital8. and i need to transfer video to PC
I'm sorry to hear that you lost the supplied CD with the Camcorder. Unfortunately, it is required to install the driver and software from the supplied CD to transfer videos through USB interface for XP OS.
This is not the case if you're using an OS which is higher than XP ( like Vista, Windows 7). In the case of Vista and Windows 7, the Camcorder has no drivers available for USB interface. Hence you can use the either i.LINK or A/V interface to transfer the videos.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
  1. Connect an i.LINK cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
i.LINK Cable.
i.LINK port.
  1. Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  1. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  2. Cue the camcorder tape to the beginning of the video footage.
  3. Turn on the computer.
  4. Start the video capture software on the computer.
  5. Begin playing the recorded video in the camcorder.
  6. Begin importing the video with the capture software.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Please click here to ask questions directly to me if you need any clarification.
Jan 13, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
Nov 07, 2009 | Sony Handycam CCD-TRV67 Camcorder
My laptop will not detect PV-DV910D Panasonic mini dv camcorder?
First you need to make sure you have the software installed for the camcorder. If you don't have the cd with the software on it you can download it from the website. You need this software because it also contains drivers for your computer so it will register the camcorder and show it as connected. Try this from panasonic.com Photovu link. i hope this helps.
Aug 10, 2009 | Panasonic Video Cameras
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
How to connect my jvc mini dv camcorder to my computer without the disc
try using windows movie maker which is free and is in your menus under xp or vista-make sure you are using firewire only to download video-not usb-need lots of ram to work w/video!
May 21, 2008 | JVC Cybercam GR-DV500US Mini DV Digital...
Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Dec 20, 2007 | IBM eserver xSeries 200 8479
I need a driver for a digital video recorder camera. the model is sony dcr-trv10.
Sony's website says: "Some digital camcorders must be setup to output a signal through the i.LINK® port prior to being connected to a computer. Consult the instruction manual of your camcorder for specific information before continuing with the steps in this solution. Instruction manuals are available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the i.LINK cable is connected securely to the camcorder and computer.
  2. Ensure the camcorder is turned on and being powered by the supplied AC power adapter.
  3. Ensure the video capture card and software are configured properly to receive the i.LINK signal from the camcorder.
  4. NOTES:
    • Depending on the video capture card and software you are using, you may need to manually configure the capture card and software to receive a signal from the i.LINK port. If applicable, check the Help files of the software or contact the video capture card or software manufacturer for further information.
    • Sony® digital camcorders are not provided with and do not require special device drivers for i.LINK connectivity. The device drivers that allow i.LINK connectivity should be provided with the video capture software. If the software you are using does not appear to have the required drivers, you will need to contact the software manufacturer.
Likely this is the case where the camcorder needs to be setup in order to connect to the Firewire port. This is done inside the menus. Windows XP and Windows Vista will detect a camcorder connected to a Firewire port automatically. Make sure your camcorder is powered up and configured before connecting it. Does your PC have a Firewire port? Many do not, PCI cards with firewire ports can be bought online or from local retailers. Some sound cards come equipped with one.
Nov 18, 2007 | Sony Handycam DCR-TRV110 Camcorder
Panasonic PV-DV200 Mini DV Digital Camcorder Logo
249 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
