Question about Dell Inspiron B130 Notebook
No programs, no buttons work, mouse works, starts but thats it
Laptop turns on, mouse works wall paper on, no buttons work, no programs loading
  • erynfoster May 28, 2009
    Thank you.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Can you get to the desktop? What exactly do you see on the screen?
    Scholar:
  • 100 Answers
Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
Please leave your feedback if issue was solved
Posted on May 27, 2009
Left mouse button works like the right betton. The right button works ok. With external mouse both buttons work fine
Go into Start > Control Panel > Mouse and check the macro settings for your left and right mouse buttons. If those are fine, then check the macro settings in the program you are using. Make sure your mouse isn't set to do the same thing for both clicks.
If that doesn't work, go to Samsung's website and download the latest drives for your touchpad. Reboot the machine and check it again.
Feb 14, 2011 | Samsung R530 Notebook
Acer Aspire 1 ZG5 3? years old. Battery is not charging and probably needs to be replaced. However, when plugged into the wall, the XP loads up and the desktop appears. The remote mouse will not function...
Te battery probably does need to be replaced only if dont like having it plugged in-- and NO that has nothing to do with the mouse--be sure you have the latest DRIVER for the mouse and be sure the mouse is configured to your likeing in CONTROL PANEL---also the "PAD" dosen't need to be turned off, you can still use a mouse at the same time
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
Dec 20, 2010 | Acer Aspire 6920-6621 Notebook
Mouse running all over without touching it
Could be a virus - there are ones that do this.
Run a full virus scan.
Apr 25, 2009 | GE 97985 Mouse
Turns on, cannot open programs
Have you tried starting in SAFE MODE? If it's an overheating problem, then safe mode won't work either, but if you can start in safe mode, then it's not an overheating issue. If you can start in safe mode (press F5 as windows is starting and select safe mode without networking) and everything seems to work sort of normally - and expect the video resolution to be weird - then there is probably a program or driver that's corrupted and when it's loading, it's freezing your computer up. It could also be a virus.
You can see what's loading on startup by using a special program in Windows called msconfig. You can start this program from START|RUN (enter msconfig in the run dialog box) and from there you can see what's starting when you boot windows. You can selectively choose programs to start or not start when Windows boots. You can try to eliminate what's causing the problem.
If it's a driver problem, that can be a little more involved to sort out.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Usb mouse problem
Did you install the CD software program that came with your mouse?
If you did and it gave you the unknown device, Then disconnect the mouse receiver from the USB port and reinstall the software program from the CD.
Then if that doesn't work try the following.
Normal 0 Turn the mouse over and find the smallrest/connect button on the bottom of the mouse and press it toReset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then pressthe mouse. This should be done whenever you change batteries orglitch.
Hope this helps you. Bud
Jan 18, 2009 | Computers & Internet
Bluetooth mouse won't work
whe u installed you mouse, you installed it from the cd from targus..right? so there is some settings in that program that you can change so when you turn on your laptop the bluetooth seeks for bluetooth items and it will find your mouse. I know its a little bit tricky but you can fix it, find the settings, change them and you dont have to buy a new mouse.
When you turn of your laptop the cooonnection betwen the item is lost, when you turn on you laptop i asume that your bluetooth is now passive, by making it active it starts immediately search for bluetooht items.
Nov 21, 2008 | Compaq Armada M300 Notebook
Frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Jan 25, 2008 | Toshiba Satellite M35X-S161 Notebook
Won't work with PC
Hi alot of people have problems working out the wireless devices. You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long... Hope this helps John
Feb 26, 2007 | IOGear 800 dpi USB Optical Mini Mouse...
GE Wireless Optical mouse 97990 Rev. 4
You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long...and repeating the same process Hope this helps John
Feb 22, 2007 | GE Wireless Optical Mouse
Dell Inspiron B130 Notebook Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
