Post Removal remove post from back of monitor (hyundai u90d)
SOURCE: system will.not post
Can anyone help me pls. fix my problem. My P5PE-VM Asus Motherboard having a problem error loading operating system. I replace my RAM, power supply and hard disk drive but seem's the error is not fix....I'm out of idea can anyone knows it and solve the problem.. I appreciate to thanks in advace!!!..
Posted on May 10, 2008
  • 958 Answers
SOURCE: wiper arm removal
first remove the bolt or nut that is on top of the shaft,. the wiggle the arm while pulling it off the shaft. that should do the trick.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • 651 Answers
SOURCE: 98 Town & Country (3.8L) alternator. Will it
yes
Posted on Jul 01, 2009
  • 75 Answers
SOURCE: I replaced installed additional RAM in my eMachine
In your motherboard there will be a CMOS battery remove that battery and put it again you will get the display in your monitor, the battery will be in coin size the battery is CR2032.
Posted on Oct 18, 2009
czaa
  • 4514 Answers
SOURCE: I need a diagram of the clutch removal and
u need a repair manual sold at parts store or viewed at ur library--thats a task for pros-special tools and safety required--make sure clutch is the issue
Posted on Sep 27, 2011
Waht do you have to yake off
We need more info to help you with the removal of your?????? Please re-post with more info.
Aug 27, 2011 | 2007 Hyundai Santa Fe Limited
Need the timing marks for 2001 hyundai tiburon
1.5L And 1.6L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L DOHC engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines
1.5L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines, 1.6L similar
1.8L (VIN M) And 2.0L (VIN F) Engines
Fig. Proper alignment of the timing belt alignment marks for belt removal and installation-Hyundai 1.8L and 2.0L (VIN F) engines
2.0L (VIN P) Engines
Fig. Oil pump and crankshaft inner timing belt sprocket alignment marks-Hyundai 2.0L (VIN P) engines
Fig. Timing belt sprocket alignment mark locations and positioning for belt removal and installation-Hyundai 2.0L (VIN P) engines
3.0L (VIN G)
Fig. Installation of the timing belt-3.0L (VIN G) engine
Fig. Timing belt sprocket alignment mark positioning for belt removal and installation-Hyundai 3.0L engine
Hope this helped (remember comment and rated this post).
Apr 13, 2010 | 2001 Hyundai Tiburon
2004 hyundai elantra oxygen sensor
Your Elantra has more than one oxygen sensor. There is a pre-catalyst sensor and a post-catalyst sensor. Both can be found on the exhaust. You simply disconnect the sensor wire and remove the sensor plug with the proper size deep socket. Be sure you have the correct sensor for replacement.
Because of the heat involved with the exhaust, make sure the engine is cool before attempting to remove and replace the sensors. They may be tough to remove so a shot of WD-40 or 5-56 spray may need to soak into the threads to ease removal. When you replace the new sensors, a coating of anti-seize will be helpful for future removal.
Keep in mind that one malfunctioning sensor can send information that will set off codes on other sensors "downstream" or send codes from other emission controls on the engine.
Mar 27, 2010 | 2004 Hyundai Elantra
Hyundai X91D power light flashing green with no picture
First place to look will be capacitors in the power supply section, look for caps with bulging tops, the problem can also be in the inverter circuits due to shorts circuits. You will need to open it up and inspect the inside, post back what you see so we can guide you further, see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Hyundai Electronics X91D (Black) Monitor
Back light does not turn on
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and see if there are any bad caps with bulging top first, post back so we can guide you furhter, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
Acer 6930 screen shakes
Go to your event viewer and see if there are warnings or errors reported there at the times you experience this issue. This would help to eliminate system errors as the cause of that behavior.
Otherwise, check for interference from nearby electrical devises, speakers, cell phones, etc.
(See here.)
If you think malware could be a factor, follow this malware removal guide.
Check the settings. See here. & here.
Finally, with an older monitor, it may help to degauss the monitor.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 23, 2009 | Computers & Internet
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Hyundai L90D+ Monitor Problem
Same problem L90D...clicking, flashing, not coming on. I just ordered a new monitor, but would love to know if this can be corrected.
Dec 17, 2008 | Hyundai ImageQuest L90D 19" LCD Monitor
PETROL FILTER LOCATION
I am assuming you would want to know the placement of the fuel filter. It actually depends if your Elentra is a Sedan or Wagon.
To my knowledge a 99 Hyundai Elentra has an inline fuel filter. It is located in the engine bay right against the firewall. It could either be on the driver side or the passenger side. It looks like a small canister with tubing connectors at the top and bottom. It is normally held by a clamp.. It maybe necessary to remove the air filter box to have easy access on removal of the fuel filter. It is a sound practice to relieve the fuel pressure prior to fuel filter removal.
If on the other hand, you are seeking locations where you can purchase a fuel filter for your 1999 Elentra, pls try here, here, here or even eBay for a start.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 11, 2008 | Hyundai Motor 1999 Elantra
Case removal
Usually a 'Snap together' operation Be craeful now - dont break a tab and be aware of high volts
May 21, 2007 | Hyundai ImageQuest B90A 19" LCD Monitor
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
