Question about Belling 24 in. IDW602 Built-in Dishwasher
Belling IDW602 Dishwasher
I have a Belling IDW602 Dishwasher and when trying to operate it I cannot get it to. When I open the door  and switch the power on with the power switch, the green cycle in progress light stays on , I shut the door and nothing happens. Even if a turn off the start stop button and switch on again, the cycle in progress light stays on. I have completely unhooked the power supply overnight and reapplyed it in the morning and then switched the start button on again  - still the fault persists. Can you help in any way.
SOURCE: Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Posted on May 11, 2008
  • 1894 Answers
SOURCE: Belling IDW604 dishwasher. Accidentally openned
have you tried to start the unit by pressing the door switch with a pen or sharp object?
Posted on Aug 19, 2008
SOURCE: belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Posted on Jan 14, 2009
  • 7 Answers
SOURCE: belling dishwasher IDW604
there is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
Posted on Aug 01, 2009
SOURCE: The door switch on my belling idw603 dishwasher is
Hi
I just had the same problem - which is how I came across your question. The spring in the mechanism had snapped and so it would not lock shut.
I have ordered a part from Belling online. I have already taken it apart and it seems straightforward.
One thing I would recommend - remove the outer facing panel first as it is very heavy. You will then find you only need to remove the top black section - make sure you turn the electricity off first and watch out for residual electricity in the control panel.
The part cost £16 with delivery. Should arrive in the next couple of days.
Adam
Posted on Dec 27, 2009
IDW 450 belling dishwasher wont heat up water
Hi, make sure you settings on the timer are working correctly first and if they are it sounds as if though the heating element may be bad or have a loose connection.
Check the heating element by the connections underneath where they plug in at and if they are plugged in if you have the knowledge you can check to see if they are getting voltage. If they are then do an ohm test across the heating element and that will tell you if the element is bad or not.
Elements are not that hard to replace and you must have the mode and serial number for the unit to order one
Jun 22, 2011 | Belling 24 in. IDW602 Built-in Dishwasher
What does E2 mean? Thanks
Hi, E2 means that anti flood device has been activated. The machine has overfilled.
Check in the base (under the bit you put the dishes in) to see if it's flooded. The causes for overfilling are blockages in the metering tank, blockages in the system hoses.
Drain the water out of the base and try the machine again. If it overfills you'll need to take the machine out, do a fair bit of dismantling to get at the hoses etc. to clear the blockages.
Jun 21, 2011 | Belling 24 in. IDW602 Built-in Dishwasher
Dishes on top shelf, usually cups and glasses, not washing correctly. Have tried rinsing cl eanser to no avail
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. Might also be worth checking the other 2 spray arms at the same time.
Jan 25, 2010 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwasher filled with liquid by mistake
ONE OF THE BEST CLEANERS IS JUST TANG THE DRINK FOR ASTRONAUTS. THE CITRUS IN THE DRINK WILL CLEAN YOUR DISHWASHER RIGHT UP.IT SOUNDS LIKE THE HEATING ELEMENT IN THE BOTTOM OF THE DISHWASHER IS BURN OUT. IT IS JUST LIKE YOUR OVEN YOU CAN SEE IT IN THE BOTTOM OF THE DISHWASHER.THIS MAY NEED TO BE REPLACED. AS THIS IS WHAT HEATS THE WATER IN YOUR DISHWASHER.YOU CAN ALSO TRY PUTTING LIME AWAY IN AND LET IT SET FOR AWHILE. THIS WILL LOSEN ANY HARD WATER DEPOSITS YOU MAY HAVE.
Feb 10, 2009 | Belling 24 in. IDW602 Built-in Dishwasher
Water doesn't empty out after wash.
Does the waster water line leading from the dishwasher to the garbage disposal exit the dishwasher upward to the bottom of the cabinet top, before going downward to the disposal? The hose cannot be laying horizontal or on the floor, and at some point, must loop at least 6 inches higher than the dishwasher.
Check that there are no blockages on inlet screens to the pump. Look closely, and don't give up until you can see the pump impeller or the end of it.
Jan 30, 2009 | Belling 24 in. IDW602 Built-in Dishwasher
Belling integrated dishwasher not working properly
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Belling 24 in. IDW602 Built-in Dishwasher Logo
82 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
