Question about Whirlpool Ovens
Our built-in electric oven will not heat
Last function performed was self-cleaning
    Scholar:
  • 174 Answers
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Jan 06, 2016 | Frigidaire 30" Self-Cleaning Freestanding...
KitchenAid oven has no heat after self cleaning complete!
You have a bad fan and your probably blew the high-limit in the back of the unit. If this is a built in oven, it's not an extremely simple fix. If it's a stand alone range, you probably broke a heating element during the clean. If its gas, you would have a bad ignitor.
Jan 23, 2012 | KitchenAid Ovens
After self cleaning it, the oven does not heat up
Seems like you found out the hard way what I wrote about in this tip...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 22, 2011 | Frigidaire 30" Built-In Single Electric...
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
No heat, either during pre-heat or bake or convection settings. This occurred after performing a self-cleaning function the prior day.
Could be:
1. bake element bad
- this can be checked, power-off, with an ohm-meter
2. temperature sensor bad
- this can be checked, power-off and sensor unplugged with an ohm-meter (should read 1080 ohms @ 70 deg F)
3. control board bad
- we repair these at www.fixyourboard.com
Oct 05, 2009 | Whirlpool GBS277PR Electric Single Oven
Kitchenaid - No heat following self-cleaning - UGH!
Can you describe the symptoms in a little more detail? Do you get the infamous F1 error on the display? Certainly the fuse is a good first check, it provides current for the heating elements but not the control circuit. If the oven control lights up, and the relays click when you try to bake ... good chance it's the fuse.
- www.fixyourboard.com
Jul 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
226 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
