Question about Alpine PDX-4.100 Car Audio Amplifier
Amp whine in boat
I have recently upgraded 2 amps in my boat to the pdx series. After disconnecting 2 other amps and utilizing the existing wiring, once the system was turned on while the boat motor is running I have terrible engine whine. I didn't have that with the previous brand amps. any idea what would cause this from the new amps?
    Novelist:
  • 150 Answers
Try isolating the rca cords away from the power cords-sometimes they pickup and transmit engine noise through the amps if they are too close together
Posted on May 27, 2009
I just install my new setup ,i have 1 pdx f4 ,1 pdx m12 and 2 sub 10''type r and my pproblems is when i put a song the pdx f4 lights become red and my mid and tweeter cut ...
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Feb 06, 2011 | Alpine PDX-F4 Car Amp
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
What is the best way to wire two alpine SWR 1222D subs to a alpine PDX 1000 1
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Sep 16, 2009 | Alpine Car Audio & Video
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
2 svcs
You've pretty much hit the nail on the head. Two 2 ohm subs in parallel would give you 1 ohm, and two 2 ohm subs in series would give you 4 ohms. 1 ohm would be overloading the amp but 4 ohms is slightly "underloading" the amp.
Your best solution with the gear you have (i.e. not buying new subs or a new amp) is to put the subs in series (4 ohms). True, you'll be putting about 200W into each sub, but according to page 4 of the owner's manual for the subs, 200W is just a tad under the optimum level recommended for the sub anyway.
Jun 19, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine pdx-1.1000
what is happening is the amp can draw the current. u need a capacitor
Apr 11, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-4.100 Car Audio Amplifier Logo
145 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
