Question about Coleman Heating & Cooling
It just quit running and wont do anything at all.
It is not running at all it just quit running all of a sudden
  • thomasp412 May 27, 2009
    Thanks for your help I found the problem it was the relay.
  • 10,865 Answers
Hello. Let me try to help you. Since it is not running at all and stopped suddenly, I would first suspect that you lost power to the unir,
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
  • Wiring (Inspect for any broken or burnt wiring)
  • Thermostat
  • Compressor
  • Overload and/or relay
  • Selector switch
  • Control board
Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Get back to me and let me know if the problem has been solved. I really do want to help you.
Posted on May 27, 2009
  • Joe Hogan May 27, 2009
    And remember, when ever you are working with electricity do not proceed if you are not comfortable with the next step.
My. 94 Nissan altima suddenly starting running
Sounds pretty terminal. Get a good DIY person to help because it could be anything from a head gasket blown to a major breakage of something. Head gasket will show up with a compression test, as will oil in the water or water in the oil. Anything mechanical will mean you have to get the tools out.
Oct 20, 2014 | 1994 Nissan Altima
1998 jimmy turns over but wont start
sounds like the coil has went bad or crank sensor
Dec 22, 2012 | 1998 GMC Jimmy
My KRB300AA1 quit running suddenly and will not restart
Could be a few things, got gas, check to see if you have a spark.
Sep 11, 2012 | Garden
My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
My 2001 pontiac grand am all of a sudden quit running.went to start it wont start.changed spark plugs nothing.took off main fuel line right at fuel rail turned key gets plenty of gas.put carb cleaner in...
It depends on the # 1 ijector to fire then the rest follow,i u have test for injectors teat the 3 1 TO SEE WORKING PROPERLY,WHAT ELSE SOMETIMES ON GRANDAMS THE INGNITION SWITCH GOES OUT....
Aug 23, 2010 | 2001 Pontiac Grand Am SE
2003 dodge durango windows, headlights, 4x4 wont work
please email me answer as soon as possible to chillinonli@optonline.com thankyou
Jul 23, 2010 | 2003 Dodge Durango
My 120gb ipod suddenly quit working.
It sounds like the hard drive has faulted. You could try a Reset. if that doesn't work. you need to have it serviced, i suspect, a replacement HDD.
Mar 29, 2010 | Audio Players & Recorders
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
Toshiba 13 inch tv/vcr quits recording audio
Does the audio "cutout" suddenly, or does it ''drift" off and on?...accordianman
Feb 28, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
Heating & Cooling Logo
104 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
