The double door gate across the driveway is closed, the electric system is not working and there is a manual way to open it. I have turned the key to manual, but the gates won't open. What else needs to be done?
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
SOURCE: Strike open light flashes and gate opens
The loose connection may be true, but i would first start out checking the track and rollers for any obstructions that could stop the gate from closing, if the gate can be closed smoothly by hand than check the ERD potentiometer on the circuit board. also peel of the blue circle sticker for the alarm potentiometer and adjust as necessary
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
SOURCE: 1. I have an elite slide gate opener it will open
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
