Question about Gateway M-6750 Notebook
Laptop keyboard is keying irratic numbers and letters
1 in a box has appeared on my laptop display and incorrect keys are appearing.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Hit the Num Lk key and it should go away and the keys will work properly.
  • Gateway Master
  • 4,806 Answers
Hi there.
Just hit the NumLock key on the top right hand side of the keyboard and it should return to normal.
Good luck and thanks for choosing FixYa!!
Posted on May 27, 2009
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
Keyboard letters are numbers and numbers are letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
Number and letter keys are stuck (type) together
This model has no numlock as it has no keypad. It looks like a faulty keyboard as the linked keys appear to be in the same column in the keyboard grid. You could try Fn+F11 as this solves certain other keyboard problems with symbols etc. Otherwise could be a new keyboard required.
May 29, 2012 | Dell Inspiron 15 Laptop
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    How doI reset my Toshiba Laptop with Vista 64 bit to factory settings?
    There are two ways to reset your Toshiba Laptop to factory settings.
    First is using Recovery Media Disc and the second is the hidden partition on your hard drive.
    If you're going to use Recovery Media Disc follow these steps:
    If you have two or more recovery media disc try to insert first the disc that has a label of 1 of 2 or 1 of 3. Then turn of your laptop.
    Make sure that the disc is inside. After that try to find the letter "C" key on your keyboard. Now turn on your laptop and keep tapping the letter "C" key. If you have successfully accessed the Boot Menu choose Toshiba Recovery Wizard.
    After choosing the Toshiba Recovery Wizard there will be a big warning screen that will appear choose the option yes and after that you will have a series of option. Remember to choose always the first option after the big warning screen appears.
    That's it. You will have a message that the Windows is initializing files.
    That process will take 1-2 hours for it to finish.
    Hidden Partition on the Hard Drive.
    Turn on the laptop and as soon as the laptop turns on press and hold down the number 0 key (the number 0 it should be on the top of the keyboard beside the number 9 key) keep 0 pressed until Toshiba leading innovation appears. Usually you will have a beeping sound when you are trying to access the System Recovery of the Hard Drive. That's an indication that you have successfully accessed the Systrem Recovery of the laptop.
    Wait for the screen that say Windows is loading files.
    After that you will see a big warning screen the choose yes and
    Choose 1st option always.
    Cx able to initialize the partition.
    Disconnect cables and turn off the wireless switch.
    Recovery would take 1-2 hours for it to finish.
    Nov 13, 2009 | Toshiba Satellite L305D-S5904 Laptop
    Jumbled numbers and text
    Look for the numlock light somewhere near the keyboard. It's the light with a drawing of a lock with a 9.
    If it's lit up. turn it off by pressing the numlock key.
    Turning it back on will activate the number keypad (consists of 9-11 keys in the middle of the keyboard). So instead of getting letters, numbers appear.
    Hope this is your case. Kindly rate me if the issue got fixed.
    Oct 03, 2008 | Computers & Internet
    Keyboard
    Okay, if I am reading this right, you type but get numbers where there should be some letters? There should be a NUM LK key or such on your laptop keyboard. It may be sharing a key. Check around, its there (or something very very similar). Once you find it, you will have to hold down your "fn" key and then tap the NUM LK key. Now type a sentence that includes the letters that show up as numbers and see if there is a change. It could be that your Number Lock key is on. Let me know if this does not work so we can try something else.
    May 24, 2008 | Compaq Presario 2100U Notebook
    Gateway M-6750 Notebook Logo
    127 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
