Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
I have a craftsman LT1000. The tractor was not used since last summer. I tried to start it but the batterry seemed to be dead. Replaced battery by a brand new one. The startet is truning but the teeth are notg engaging the matung teeth to start the engine. I thought I had a bad starter: got a new one & replaced it ... same problem. What else can cause this problem. I have a Craftsman LT1000 - Tractor has been great no problems for last 5-6 years however; this year It suddenly started sputering and spitting and running uneven while under load. I replaced air filter, fuel filter, spark plug - which seemed to fix the problem for about 5 minutes. Until it starting running poorly again. I checked the spark plug (not fouled) and i checked spark plug is getting blue spark. However; Now she will not start. Original Fuel Filter didn't seem blocked (unable to get a replacement - discontinued according to SEARS Hardware - but same exact stock # as brand new mower :(!) Replaced with Briggs and Stratton Standard In Line Filter. I am stumped on this one! Help Please I'm not a mechanic so I would appreciate some help. Thanks Much!
  • tomtopshelf May 27, 2009
    **Please Read *** Correction - I am not having teeth problems - not sure how that got in there.
    I have a craftsman LT1000. The tractor was used 2 times since last summer. I have a Craftsman LT1000 - Tractor has been great no problems for last 5-6 years however; this year It suddenly started sputering and spitting and running uneven while under load. I replaced air filter, fuel filter, spark plug - which seemed to fix the problem for about 5 minutes. Until it starting running poorly again. I checked the spark plug (not fouled) and i checked spark plug is getting blue spark. However; Now she will not start. Original Fuel Filter didn't seem blocked (unable to get a replacement - discontinued according to SEARS Hardware - but same exact stock # as brand new mower :(!) Replaced with Briggs and Stratton Standard In Line Filter. (States fit's all 1/4" and 5/16" mowers up to 80HP. Now mower will not start. tried using original fuel filter however; same result will not start. ( I am stumped on this one! Help Please I'm not a mechanic so I would appreciate some help. Thanks Much!
    I also replaced the original battery with a new Everstart. Not sure if these mowers have magnetos. Anyone have any experiences with regards to fuel filters I can provide model number if needed.
    -really appreciated!
  • 420 Answers
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Posted on May 27, 2009
  • Mike Squire May 27, 2009
    What color were the spark plugs when you took them out, white means too lean (not enough fuel) black means rich (too much fuel)
You carburator just needs to be cleaned/adjusted, and if your original fuel filter isnt clogged and looks clean, leave it, but the air filter is a good idea to change at least once a year (grass shavings covered filters dont help the engine much).
Posted on Feb 20, 2010
2 Suggested Answers
  • 260 Answers
SOURCE: Lawn Tractor won't start
try replacing the relay in the middle of the ignition and starter.
Posted on Apr 11, 2009
Craftsman tractor. Will not crank over ,
Mike, problem could be a lot of things, weak/dead battery, starter/solenoid faulty, bad fuse/wire, Faulty safety switch, seized engine, engine in need of valve adjustment,etc. You may have to have checked, diagnosed and estimate for repair by a small engine Tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.cubcadet.ca/wcsstore/CubCadetCatalogAssetStore/Attachment/articles/2008_SevenProblems_revised_5_19.pdf
MTD Products
Lawn mower won even turn over
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 23, 2016 | Craftsman Garden
Where is the spark plug located on my craftsman lawn tractor model 917.273360
James, it is at the front of the engine. It is next to the 4" by6" metal cover that says OHV. It is on the right hand side ( sitting on the tractor), There is a black wire the size of a pencil ( diameter ), hooked to it. It is set deep in the engines cylinder head. There is a rubber boot over the end of the spark plug. Remove the rubber boot, you will hace to grip it hard and pull it off. Then you will be able to remove it, using a deep 5/8" socket with a 4 to 6 inch extension.
Hope this helps, if you need more let me know.
Matt
Dec 02, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My tractor dies randomly. it just bogs out, and dies. it might start right up or it might take awhile. I replaced the coil, fuel filter and made sure the carb was clean.
Craftsman 17.5 hp 42 in. Deck Lawn Tractor model 917.272670 ohv, 0 compression, removed head found valve seat insert out/on angle, valve unable to close. Can this be re-seated, adjusteded or is new head required? Rich
Aug 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
Jun 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor won't start after only one summer's use.
Is it fresh gas? Gas deteriorates over time. If it is from last year your carborator is probably clogged with residue and needs to be rebuilt or replaced (if cheaper).
Apr 30, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp/ohv craftsman 42in wont crank
One thing to check, see if there is a piece of root stuck under the tractor there is interrupting any of the security features from allowing the tractor to start. It might be a small piece that stops a plunger from engaging.
Mar 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
2,601 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
