Question about Maytag Dryers
My dryer doesn't appear to be drying as fast as before.
My Maytag front load electric dryer (PYET444AYW) takes longer to dry than before. Is something burning out? Can I replace it myself?
  • 56 Answers
First check with a clamp amp meter and see if ampage corresponds to dryer wattage,wattage=voltsxamps,when running,if not its an element or element connection problem,if ampage is ok check if vents etc area ok,lastly if heating ampage is cutting out before it reaches its temp its the stat hope this helps.also safety is foremost when checking electrics ,hope this helps
Posted on May 27, 2009
  • Maytag Master
  • 4,655 Answers
Most times this is because there is a restriction of the air flow leaving the dryer exhaust pipe. This will cause a buildup of heat and cause the high limit to turn the heat off. If clearing the exhaust pipe of crimps, dust or clogged line does not help then let me know. Thanks, Sea Breeze
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
Help Changing Belt on Maytag PYET444AYW dryer
Normally if it is a front loading machine then you need to take the front of the dryer off.
This will expose the drum, roller, etc.
Remove the drum, install new belt on the motor pulley, loop around the idle arm roller, then install on the drum and reinstall the drum, reinstall the front and job complete
Sep 26, 2009 | Maytag Dryers
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer takes forever to dry clothes!
it could be the vent pipe is clogged. check that out too
Jul 05, 2017 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
