Question about HP PSC 2210 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
When I press enter it goes for a few seconds, then says alignment cancelled, it prints a page with a long and short line and then the screen flashes press enter to align cartridges my printer is showing on the screen press enter to align cartridges
    Scholar:
  • 44 Answers
In my experience, usually alignment is canceled because one (or both) of the cartridges is not printing properly, and needs to be cleaned.
Hopefully, your alignment page will have printed something before it got canceled. Look at it and see whether the print is in color or black -- then clean whichever cartridge is NOT printing. (Search for "how to clean HP/Compaq/Brother etc. cartridge" for details of the right way to do it for your particular printer. What often works, though, is to take a Q-tip, moisten it with hot water, and gently rub the print head. You can escalate from there to immersing print head in boiling water, using water/alcohol, using an ultrasonic cleaner, etc.)
After you've cleaned the cartridge, the printer may say "remove and check cartridge." Sometimes, all you have to do is take it out and put it in again.
Posted on Jan 20, 2012
  • 5 Answers
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
Posted on May 27, 2009
Every time i try to copy the screen says "press enter to align cartriges
Have you carried out a head alignment procedure, I would carry that out again
the online user manual is available from this link http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge. Aligning the cartridges ensures high-quality output. To align the print cartridges when prompted:
  1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
  1. Press Setup.
  2. Press 5, then press 2.
  3. This selects Maintenance, and then selects Align Print Cartridges.
  4. A page of patterns is printed. The cartridges are aligned correctly.
  5. Recycle or discard the page.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
"Press enter to align cartridges"
Try removing the ink cartridges and cleaning the electrical both on the ink and iside the unit with some rubbing alcohol and qtip then reseat them back into the unit and see if that works
Feb 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
249 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
