Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
AKAI CFTD2011 The sound goes out and then the picture goes out then the sounds come back but no picture.
  • Ronald Lambert
    Ronald Lambert May 27, 2009
    My AKAI CFTD2011 is doing this: first the sound goes off then the picture goes off then the sound comes back on but the picture stays off. Can you tell me my problem?
  • Ronald Lambert
    My AKAi CFTD2011 is have this problem: first the sound goes off and then the picture goes off and then the sounds comes back but no picture. If I turn the TV off the picture comes on but goes off again and then the power too. Can you help. Thank you.
    President:
  • 2,004 Answers
Your problem could be a backlight problem. But the bulbs may not be the source of your problem, as both and sometimes 3 or 4 bulbs, depending on the set will not all go out at once. You most likely have an inverter problem with your set, that is the circuit that powers the backlights.
Don't forget to rate this please.
Posted on May 27, 2009
  • Onifade Adewunmi
    Onifade Adewunmi May 28, 2009
    I wonder if you had a look at the solution I posted.
    Murphybanton
    President:
  • 2,923 Answers
You need to check everything to isolate the problem. Start with the physical connection. Please follow the steps below:
1. Check the wall outlet and make sure that it is a known working wall outlet.
2. If you are using a surge protector or power strips, make sure that it's clean and properly working.
3. Check with the cable provider (i.e. Dish) to see if you need to change some settings. Because it could be the cable provider problem.
Aside from that, the only thing that I could think of is your TV could have a bad inverter board.
You need to consult with the TV manufacturer for second opinion.
I also provided you the link so that you could see how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/index/?q=INVERTER+BOARDS&stock=all
    Sergeant:
  • 296 Answers
HI
If it's an LCD, take a close look at the screen with a Flashlight and see if you can see some sort of picture (Almost like a ghost of an image). If this is the case, the backlight has failed.
If it's a plasma unit, you're probably looking at a power supply issue to the panel.
REGARDS
I am looking for the specs for the wall mount screws on the back of an AKAI CFTD2011 20
If not in the USA contact AKAI in the UK for length and thread type of bolts used for that model for a wall mount.
Jun 13, 2012 | Akai CFTD2011 20 in. EDTV-Ready LCD...
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Televisin does not even show red power light
sound like you might have blown a fuse, or the power supply board is bad. if you can take the back off of the unit and check the fuse it is located right where the power comes into the unit, if that is good look at the power supply board and look at the caps in particular and see if they are bulged out like in the picture below, replace them and you will be all set...
Apr 25, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Flashing red lite..black screen
You have a defective power supply or another of the the processing board ... depends on the number of flashes ... please take to agent for complete diagnosis and repair
May 12, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai tv remote control
Go to Tigerdirect.com order Logitech Harmony 520 universal remote it is compatible with your AKAI CFTD2011 same as mine. Phone number is 800-800-8300. I also called logitech that makes this remote and it is compatible..........finally a remote that works.............
Mar 11, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
No owners manual for akai cftd2011
I have one downloaded on my laptop and can email it to you. I don't want to display my email on this thread though. Any ideas how to communicate without displaying our info publicly?
Jan 21, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Only two channels akai CFTD 2011 20in
no u nee dto scan for chs ? let it find them all over agian ok
Jan 06, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai CFTD2011
You need to repair the SMPS - - common problem! Open the back and locate the SMPS (Power Supply) On it you'll find a series of electrolytic caps with position numbers. Replace C31 (1000 25v), C32,35 both (1000 Uf 25v) and C33 (680 Uf 25) and you should be good as new...
Bill
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Problem with sound and picture
sond slike bad tv almost is your power strip grounded well bets one is monster clean power clean up older homes power so dirty in usa cuses flat screens to die out elery if u have up down voltage in house also cheak hd antenna whos your cable from charter or dish
Nov 26, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
93 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
