Question about Hotpoint Aquarius WMA56 Front Load Washer
Beko machine knocking when on spin dry
    Problem Solver:
  • 5 Answers
Probably a balancing spring broken the load will go to one side of the drum when spinning.Needs to be taken care of before it rattles itself to death
Posted on Oct 30, 2007
4 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: beko aa washing machine does
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Sep 15, 2008
  • 1294 Answers
SOURCE: beko wahshing macnine wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: beko wma150s does everything it should except spin
It appears your lid switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
My beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
Hi christophe if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Oct 30, 2012 | Washing Machines
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 10, 2012 | Beko Washing Machines
Wont do final spin
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Hotpoint Aquarius WMA56 Front Load Washer Logo
110 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
