Question about GE DBSR453GBWW Gas Dryer
Light in dryer only lasts a few days. Verified the voltage at bulb socket is 120 VAC. Replacement bulbs are 120 VAC.
Light in dryer only lasts a few days. I checked the voltage and it is 120 VAC. The replacement bulbs are 120 VAC.
    President:
  • 1,136 Answers
Hi, are you replacing them with appliance bulbs and not regular house bulbs?
Vic
Posted on May 27, 2009
Replaced dryer drum bulb but light won't come on
First, test the bulb you just installed to make sure it works. Assuming it is a 110-120v bulb, you should be able to do this with any standard lamp in the house. If it's good, next test the socket in the dryer to make sure it has electricity going to it. Do this with a multi-tester and please be careful -- this is a live circuit. Set the tester to its highest AC Voltage setting. Touch the center "button" of the socket and with the other tester probe, touch the outer screw-in shell. It should show 110 to 120 volts. If no power, you'll need to break into the back and make sure all wires going to the socket are connected . . . which may have become jostled.
Aug 20, 2014 | Kenmore Dryers
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
Light does not work even with a new bulb
GET A MULTIMETER CHEK FOR THE LIGHT SOCKET PIN IF YOU HAVE 120 VAC THOSE PINS ARE NOT MAKING CONTACT WITH LIGHT BULB IF NOT VOLT OUT REMUVE THE INTERLOCK SWITCH CHECK FOR CONTINUITY IF NOT CONTINUITY ON THE SWICH REPLACED THE SWITCH..
Feb 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a hitachi 55vs69 projection television. Lately, it has been shutting down every 15 minutes or so. The screen turns dark but you can still hear video until about a couple minutes later the led light...
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
  1. Lightning and other 120 vac power bumps.
  2. Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
  3. Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
  4. Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
  5. Poor quality or damaged bulb installed as replacement.
  6. Bulb damaged during replacement
  7. Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 08, 2010 | Hitachi 55VS69 55" Projection HDTV
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
I had to replace the 7 volt light bulb in the dryer. Lowes gave me a 6 volt and the bulb blew. No with a 7 volt it does not work. Do I have to re-wire or is there a reset switch on it somewhere?
no reset check the bulb holder wiring for 120 volts to the socket
if 120 present unplug the dryer and inspect the socket for problems
Apr 25, 2008 | Dryers
Freezer Light
You can try tapping the light switch (snapping it on and off) to see if that helps but this usually would require a voltage checker or multimeter to test for 120 volts at the socket of the bulb. If you're not comfortable with electrical stuff, don't stick test leads into a live socket... Basically you will somehow need to determine if the switch is the problem by pulling it out and testing for voltage, etc. Some models have a thermal overload to kill the power to the light if it should stay on for some reason, that could be bad too if you have one installed. This type complaint is hard to resolve unless you have the test equipment to explore where power is or is not.
Dec 19, 2006 | Whirlpool GD5SHAX Side by Side...
GE DBSR453GBWW Gas Dryer Logo
357 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
