Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Refrigerator will not go on.
My Whirlpool rerfrigerator / Freezer is not working at all . I pulled the plug & tried another appliance , the other appliance worked . I replugged the refrigerator , turned it off & than back on . The refrigerator does not go on . Thanks, Dan Pieczonka
  • danstackle May 27, 2009
    Hello Sea Breeze,
    My Whirlpool is a side by side ,Model #ED20AKXSN00. The lights in both the refrigerator & freezer work when pluged in . Additional info 6.5 Amp ,6.25 oz. refrigerant , Mfg. 0288 , serial # S80823654.
    No sound coming from unit .
    Thanks for your help.
    Dan Pieczonka
  • Whirlpool Master
  • 4,654 Answers
I will need your model number to help you better. Below is a photo of where you may find the number. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 27, 2009
How do I fix the freezer light in my Whirlpool side-by-side/freezer on bottom fridge?
first make sure the light bulb works for sure. then most likely it is the door switch. easy to replace. pull out, disconnect and replace. while you are at it, touch the two wires together and make sure the light goes on so you know it is the switch.
Aug 09, 2015 | Whirlpool Refrigerators
Freezer gets cold but rerfrigerator does not on my side by side model TFX20JEX
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | GE Refrigerators
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Fridge light comes on & sound but not cold
The freezer fan motor may be bad. The main back panel in the freezer can be removed to check it out. Spin the motor wiht your finger to see if it tries to run. If it does then it is shot.
Go here for:
Whirlpool Refrigerator Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side refrigerator - Freezer not cooling
Kharris11762, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Kharris11762), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 16, 2017 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool side by side just stopped working,
The only logical conclusion to this is that the fuse is blown in the plug or on the fuse board. Even if the motor expired the light would still work. Have you checked the plug/fuse and board or even tried plugging the appliance into a different outlet?
Oct 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
New refrigerator does not cool
hi. thanks for the question. go back to costco .and get a new one .thanks the appliance doc
Oct 05, 2008 | Whirlpool Refrigerators
The refrigerator section is not cold enough but the freezer is fine on my Whirlpool top freezer unit. my refridgerator isn't cold even with it turned all the way up but the freezer is working fine. I own...
Hi thanks for the question check to see if the freezer fan is working if not replace. check to see if you have frost build up in freezer if you do you then have a no defrost problem. pull fridge away from the wall, remove the back panel, clean all lint. thanks the appliance doc
Oct 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
