Question about LG AX830 Glimmer Cell Phone Car Charger
Screen won't respond to touch
My LG UX830's screen wont respond to touch. It turns on and everything but the screen wont react. What is the problem?!
Put mailing tape across the screen then lift it off. I think that the sceens get stuck together and when you take the tape off it "unsticks them".
Posted on May 30, 2009
  • e_writes
    e_writes Dec 01, 2012
    thanks! it worked!
Welcome to LG-LG 855 won't respond
MY BOOST MOBILE IS AT THE WELCOME TO LG-LG855 SCREEN IT SAID TOUCH THE ANDROID TO BEGIN WELL IT NOT DOING ANYTHING WHEN I TOUCH IT WHAT DO I DO
Mar 11, 2012 | Cell Phones
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
Need to calibrate touch screen for alltel touch screen phone.
I need to know the model of your alltel phone. Its under the battery. its usually the numbers and a letter.Or if you know the name of your phone that helps too.
Jun 10, 2010 | BargainCell USB Data Cable + Rapid Car...
My lg wont respond to me touching the screen
take the battery out and leave it out for a few minutes put it back in if this keeps happining call att and get a replacement phone
Mar 13, 2010 | LG Xenon GR500 Cell Phone
LG UX830 (LG AX830) lcd
the screen sounds like a wire came off....if you have insurance on the phone I would go through the provider and get it replaced....or if it is less then a year old it should still be under warranty. I have a used but good LG Glimmer for sale if you are interested.
Oct 08, 2009 | LG AX830 Glimmer Cell Phone Car Charger
Put mailing tape across the screen and lift it off.
May 28, 2009 | LG AX830 Glimmer Cell Phone Car Charger
Broken touch screen
Sounds like a broken digitzer, this is the front fascia. You can bring it to a mobile repair centre and get it replaced, or attempt it yourself. Should however still be under warranty so can bring it back and get it fixed free of charge though you will have to wait several weeks
May 27, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
White screen on my lg ux830
user screen cable is mis placed. its not much big problem.. open the screen urself and adjust it ( is like plug-in)
May 09, 2009 | LG Vu CU920 Cellular Phone
Touch screen on lg ku990 seems slow
they reckon if it has a screen protector on it it is "slower" to respond. So if you do have one off... remove it. but yes I do believe my touch screen is abit delayed even without a screen protector :(
Apr 28, 2009 | LG KU990 Viewty
Lg ux830
easy, it depends on what song format you have your audio files in that you want as a ringtone, if they are mp3s you cant use them, i have the lg ux830, i dont really like it anymore cuz the touch screen is so futile and total ****, well anways back to your question, just go on your computer and convert the songs to a .WAV format and they should be able to play
Dec 07, 2008 | Cell Phones
LG AX830 Glimmer Cell Phone Car Charger Logo
655 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
