Question about Dell 8xDVD/24xCD Drive for Latitude/Inspiron Laptops DVD Drive
Unable to Open DVD Drive.. have Fujitsu drive
Unable to open DVD Drive. But while starting the system it is showing light green color, but not later on. Unable to open the Drive.
  • saran123 Oct 21, 2007
    It is Dell Inspiron E1505 Laptop.
  • 188 Answers
May be u r drive door s are stuck.....try to open it by a needle....
or further it is damaged u can replase it if in warrenty.
dont forget to tell me u r problem solved or not
best regards & best of luck..
Posted on Oct 27, 2007
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..
How do I get my dvd/cd to start when I put it in my computer?
You can go to file explorer or file manager and click on the drive letter of your CD/DVD which is usually like a Drive D:, E: or later drive letter.
Once you click on the right driver letter in file explorer it's going to try to read it. It will then open up the files on the CD/DVD or try to start the application you may have installed for reading a CD/DVD.
If you don't have an application installed to view the CD/DVD it may give you a message that "Windows could not find a suitable application to open your file.." but it will ask to pick which application you'd like to try and open the CD/DVD with. Something like media player should show in the list if you have it installed.
Oct 14, 2015 | Microsoft Computers & Internet
My Fujitsu Siemens laptop DVD Rw AD7590aATA device not working. Its showing code 19 prblem. How can i fix that problem?
Try Both of these steps to fix the issue.
Please press the windows key on your keyboard , hold it down, and press R
Type in devmgmt.msc and press enter
If it asks to open, click yes.
Then, you should see a list of devices installed on your computer..
Double left click the cd dvd drive choice to expand it ... Then..
right click on each listing inside the cd dvd section..
And click uninstall.
Once uninstalled. restart the computer, and test the cd drive..
It should now be working in windows normal startup!!
Then, if its still not working normally.
Go to the link below.
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive!
Feb 15, 2011 | Fujitsu Computers & Internet
In a Sony vaio the Fujitsu hdd reports an error and is unable to boot. When I hook the hdd up to a different system the files are accessible and usable. (ex. You can play music that's on it). How can I...
When you connect the Fujitsu to the Sony laptop. use disk management utility to see how the how the sony is characterizing the Fujitsu. If you can access the files on the Fujitsu from another computer, the Fujitsu is not faulty. Your connection with the Sony is the problem. Disk management utility instructions are listed below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
I hope that this information is helpful, if so, please rememeber to leave positive feedback.
Thank You,
Feb 13, 2011 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Blinking green light/won't detect disk drive
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
May 22, 2009 | Microsoft Xbox 360 Pro System Console
Disk drive won't open & lights flash
samsung told me it was defective and to send it in at my own expense. Throw it out and dont buy samsung
Jan 07, 2009 | Samsung DVD-P241 DVD Player
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
DVD and CD drives not working
Drive may need a firmware update. If you have internet access then go to drive's manufacturer, and check for an update. There could also be a drive configuration problem, need to see if drives are recognized, by the system.You can right click my computer select explore and look for drives or go to settings, control panel right click system, open, then hardware, device manager. Then look for cd and dvd drives. If you see yellow exclamation marks or question marks then updates drivers. This is a start, try to see if the drives recognized.
Dec 16, 2008 | Compaq Presario 5000 PC Desktop
Problem while opening hard disk drive.
unable to open my computer drives like C, D.whenever i double click the drive it show open with some programmes.I bought three month before.Begining it open when i double click but now it is not possible
Aug 14, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Pioneer DVD Burner Drawer will not open
hi rscarboro
on the left side of the dvd drive there is a small little hole which you can insert a paper clip etc to open the draw
push it in this will open the draw for you.
Jun 26, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Drive won't open
u can see a pin hole on the drive just above the open button or the green the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Computers & Internet Logo
185 people viewed this question
Alun Cox
