Question about Kitchen Ranges
Burning plastic smell
Kenmore stove Model 790.9743, in daily use for a few months, still smells like burning plastic whenever I use the oven. I assumed this was just an initial "burning off," but three months? Is there a way to hasten the process, or is this something wrong?
  • colin_montoy May 27, 2009
    It's electric.
    It's a solid cooktop, and I don't see a way to lift it. I think you're right; I should just call for service. Thanks for the help.
    Colin
    President:
  • 1,136 Answers
Hi, Sounds like something is wrong. Is this a gas or electric oven? Did you have to change settings from natural gas to lp?
Please let me know, I would like to try and help you.
Vic
Posted on May 27, 2009
  • Victor
    Victor May 27, 2009
    Ok, If you can raise the top panel on this model, check and see if anything might have gotten under the top. Do you smell it while using the topp burners as well?
    There should be a one year warranty. You might need to get a service tech to check this out.
    Vic
    New Friend:
We have had a new Frigidair oven for a few months, the first time I used the oven broiler blue/white smoke started pouring out the oven vent and continued for 5 minutes after shutting it off. Having worked as an electrician for years I knew immediately it was wire insulation burning and informed the repairman of that when he came, but he also didn't leave it on very long and claimed the the smell is some chemical burning off the elements. It was and still is very obviously wire insulation burning and several months later is still giving me headaches and making me feel constantly ill as I have no choice but to use it every day and even with fans on and the doors open during -6 weather I feel horrible. I'm just about to take it apart myself since I can stand it no longer and Frigidair service is useless. It likely is going to result in a lawsuit, DO NOT BUY FRIGIDAIR IF YOU CARE ABOUT
YOUR HEALTH!
Posted on Feb 02, 2017
That's funny that you mention this because we just bought the very same oven a few months ago and just installed it.I have used it only a few times and like yours it has the burning smell, I thought the same as you that its because it is new. Anyway when opening the door to put in a pizza I hear something rattle which sounded like it was in the door. I could not see anything, I open the bottom drawer and there was a black plastic piece about 1 inch long of something, not sure what is is, I thought may be the door latch but it looks OK. For the life of me I do not know what it is or where it came from. I have sent an e-mail to Sears and should hear from them soon.I do hope that it is not part of the oven (inside). I just cannot understand why things are made so cheap and flimsy these days. Mean while I suggest looking all inside your oven for any foreign plastic parts. I do hope that it is just part of the packaging and not something that goes to the oven.
Posted on Jun 06, 2010
Why would it smell like plastic burning when my oven heats up It is a older hardwick gas stove
this is very common on new ovens , seems the mfg use preservatives on metal parts that needs to burn off
it should go away after just one or two uses
of course its your choice if you use it for food in these 1st few heat cycles
Oct 28, 2015 | Kitchen Ranges
I have a stove 61ehdo stainless Steele cooker which tonight has just stopped working I've had it approximately 7yrs . Oven rings etc won't turn on . I was in the middle of making dinner when this happened...
If you smelled a plastic burning smell you've burned some wiring somewhere. You would need to pull out the whole thing and start by looking at the back. I once had a dead mouse that had shorted across the relatively high voltage terminals common on most stoves. You should unplug the stove before doing anything like removing panels. Be very careful. Once you've found the problem you might need to call an electrician to fix it, depending on how brave you feel and where the problem is.
Feb 16, 2015 | Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Mar 27, 2013 | LG Ranges LRE30453ST 30 Inch Freestanding...
Kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Apr 11, 2009 | Microwave Ovens
Burning plastic smell coming from new cooktop fan.
Sorry - this is not an answer but a question. Did you get your problem resolved. We just purchased a induction stove & oven and are having the same problem you described. Could you let me know what happened. Regards Bob
Apr 06, 2009 | Kenmore Elite 44173 30 in. Electric...
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Gas oven smell
Have you checked the temperature with a hand held or stand alone thermometer? First thing I would do is get a cheap oven thermostat, set the oven to 200 and make sure the oven is not being controlled.
This smell, does it sour the flavor of whatever you are baking, broiling whatever?
Sounds to me the oven might be over temperature, if it checks out against another thermostat is there any breakin procedures in your manual or cd?
Check that out, next have you called the oem?
cALL EM AND TELL THEM WHAT YOU ARE EXPERIENCING, MAYBE THEY HAVE A BAD COATING,
If that goes no where, get a mailing address, ,get a frozen pancake or waffle if it is sticking to the food, cook it, wrap it hot in plastic rap then aluminum foil and mail it to them.
Once they take a wiff of it you will get some relief,
I am concerned you might have some kind gas that could prove to be unhealthy, so get this dealt with, the three suggestions above should get you an answer.
Will
Nov 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
1,145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
