LG PVR LST 5403P Remote Control
Hi I cannot get my LG rmote that came with the LST 5403P PVR to recognise my Panasonic 43 inch (106cm) Plasma Tv however my previous LG set top box one worked ok - can u help
Thanks
Bill
  • Anonymous Jan 30, 2008
    i have a palsonic lcd tv abd there arent any codes in the book for mine
IrishDruid
  • 2712 Answers
SOURCE: Giant Omnitech remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Posted on Feb 14, 2009
RATTROD
  • 8 Answers
SOURCE: i have a 50 inch lg plasma tv and the picture is to big.
Ok take your Vizio remote control go to the Lower section of the buttons and look for the - Zoom + button than decrease the zoom.
Posted on Jun 22, 2009
  • 102 Answers
SOURCE: Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Posted on Sep 20, 2009
SOURCE: MOTOROLA DCT2524/1631/AL DIGITAL CABLE DECODER
what is 074
Posted on Dec 20, 2009
Need a remote control code for a gva 106cm plasma tv
Check this site they add new Plasma TV Remote's Weekly or use a universal from any local store such as Best Buy, if you want an original E-bay is best bet.
Feb 17, 2012 | Televison & Video
My hard drive has failed in my LG LST-5403P PVR. I put in another (smaller) hard drive, but the unit still says "hdd failure" and won't format it. What can I do to get it to recognize the new...
If LG do as Poineer do, the hard drive has to be added to the system with a special service remote and a code. Maybe a drive of identical size may help?
Good luck.
Jan 08, 2011 | Televison & Video
LG LST-5100P set top box does not display menu with an older ( 1998) tv set. Cant select aspect ratios . All I can do is change channels. Any ideas? Rod
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 22, 2009 | LG LST-4200A DTV Receiver
Gdex-2000 remote control codes and/or user manual
Good morning , I need a remote control code for the Memorex TV Model # MT 1091. I have in my possession a GDEX-2000 remote
Jun 05, 2009 | Quasar VV-1302 13 in. TV/VCR Combo
LST 5402p firmware upgrade
How do i update my firmware on my LG LST 5402p recorder from home??
Apr 12, 2009 | Televison & Video
Remote Control Code for Goodmans GHD8150F2 PVR
not all universal remote control work with everything, even if the product is listed.
You MUST try every code in the book and see if another company code works.
Nov 29, 2008 | Televison & Video
LG 42PC5D 106cm Plasma
Hi Amhouston,
Can you turn it bak up again, manually or with the remote?
Dave
Jun 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Remote code for Sony Homethetre on LG Remote
LG 32 LX2R TV REMOTE CODE TO WORK A SONY VTX-D8 U
Dec 30, 2007 | Televison & Video
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
