I was wondering what the extra wire attcahed to the audio cords it looks like a speaker wire
I was wondering what the extra wire is for attached to the audio connections. It looks like a speaker wire. Regarding the marantz TT 2200 turntable. I'm finding that the sound only traveles through one speakeer itsead of 2. thanks Jeff
  • 141 Answers
The bare stripped wire is for grounding the turntable to the receiver to eliminate any hum sound. If after connecting both phono plugs, you only get sound from one channel on the turntable but sound plays out of both channels on all other inputs then replace the phono plugs as this is the most likely problem.
Posted on Jun 05, 2009
How do I wire external amplifier
In order for this to work correctly you need:
  1. Power wire (with fuse) from battery to amp (+)
  2. Ground wire from amp to car chassis. (-)
  3. remote-on lead from a 12V power source that turns on and off with the ignition if the head unit does not supply a wire. (switch)
  4. RCA connection from head unit to the amp. (sound in)
  5. Speaker wire connection from amp to speakers. (sound out)
It is easiest to start with deciding on the amp mounting location, and then running all the wires. Add an extra foot or so to each wire. You may discover in the process that you have to move things around due to unforeseen obstacles. This extra foot will help in that case. Always attach the ground wire to the chassis first and then to the amp first. Once you have the fused power wire from the battery installed; remove the fuse before trying to attach it to the amp. ONLY re-install the fuse once all connections to the amp are made, secure, have been checked twice and you're ready to test it.. This includes speakers. DO NOT for ANY reason have the amp powered up before attaching ALL speaker connections.
Feb 23, 2015 | Panasonic CQ-C1100U CD Player
I lost all the connecting wires and plugs for the iH70S, how do i replace them
Check to find where power goes in, and look at the voltage. Look around your house for extra cords that have this voltage. If you can't find any, look online like eBay for a cord for it.
Jan 11, 2013 | Apple Ihome Ih70 Computer Stereo Speaker /...
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
Speakers attachment
If it is powered speakers type (you can tell if it has ac adapter or power cord), then yoy will use that green ministereo audio input plug of the powered speakers and attache it to the PC green audio line out, you do not hook the speakers to the monitor. Please vrify what you have.
May 15, 2010 | Envision EN-7410 17" Flat Panel LCD...
How to attach the cord on the whirlpool dryer model ler3624eq0 -- was working fine, then when i moved it to reconnect the vent, heard a 'pop'. wondering if it's connected correclty in the first place
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Aug 30, 2009 | Dryers
EXTRA SET SPEAKERS
Look on the back of the receiver where the existing speaker wires are connected. There should be some jacks there to connect 2 more speakers. There are 2 wires per speaker, put one in the red and one in the black. Some receivers have a button to turn on/off the extra speakers so make sure it is turned on if you have one.
Jul 06, 2009 | Marantz SR-19 Receiver
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
My system is protect status
Check the connections of the speaker wires. You may have a short between one of the pairs. Try disconnecting the extra speakers if nothing is obvious. It could be a damaged cord also.
Ted
Nov 06, 2008 | JVC HX-C6 Shelf System
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
237 people viewed this question
 Grubhead
Grubhead
