Question about Freezers
Frig is not getting cold at all and the freezer is not freezing Thanks
The freezer is not freezing but kind of cold like the frig should and the frig part is not getting cold at all. Thanks
  • jenkins11tar May 27, 2009
    Yes there is ice on the back wall just a little and Model # is msd2757AE
    Its frosty and no ice on bottom. The back is all frosty
    President:
  • 1,136 Answers
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
Posted on May 27, 2009
  • Victor
    Victor May 27, 2009
    Ok, If it is ice and not frosty, the drain has plugged inside the freezer and possibly plugged the air vents.
    You will need to rremove the rear cover inside the freezer and get the drain unplugged. Are you seeing ice under the botton drawer in the freezer?
  • Victor
    Victor May 27, 2009
    What you need to do is test the defrost hearter and bi-metal switch first. DO you have a voltage/ohms meter?
    Remove the lower half of the rear panel and start melting some of the frost (hair dryer works great.)
    locate the defrost heater (black in color) and find the plug in harness. Check continuity on the element to see if it is open. If it tests open, replace the element.
    Now locate the bi-metal switch that is attached to the evaporator tubing. Again, if it shows open, replace the bi-metal switch. Note: this is the most likely problem.
    If both the bi-metal and element test ok, the only part left change is the defrost timer board located in the control panel in the fresh food side.
    I know this is a lot of info so, if you need clarification on anything, PLEASE ask.
    Vic
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
FRT21FR6A Frigidaire Top freezer not freezing and refrigerator not getting cold enough...what could be the problem? Just got it used
Have you cleaned out all the lint under the frig, Use a vacuum and a brush clean from front and rear of the frig. if not then the freon is low and it needs a charge
Aug 19, 2009 | Freezers
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Electrolux frost free fridge freezer not workinge
think your frig heater or terminnator is bad,all this is behind the freezer panel,also but i'am not sure your frig. might be stuck in defrost,you find this out by pulling the frig. out and listen for 25 minutes to see if it cuts on,if you hear it running already then it's one of the other problems,hope this helps-mike
May 29, 2008 | Freezers
Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
May 25, 2008 | Freezers
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
289 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
