Question about Kenmore Dryers
Timer runs backwards
I need to see if I need to replace the timer. Timer sometimes runs backwards. I will set in in automatic cycle and it runs counterclockwise. Sometimes it does work but at times it does not. Do I need to replace the timer? Most forums say I do not. I want to see what I need to do. Any help would be appreciated.
  • 56 Answers
Looks like the timer is starting to fail,hope this helps
Posted on May 27, 2009
I need the compressor to run for a longer period of time. what do I do? Does the defrost timer has anything to do with it
Yes, when the defrost cycle is running the compressor isn't. Defrost timer should run a defrost cycle twice a day. Interval is 12 hours, defrost usually takes 20 to 30 minutes. Some cycle the compressor backwards slowly to warm the evaporator and melt the frost faster. I had a commercial walk in freezer that defrosted every 2 hours and had an evaporator heater element. The timer switches off the compressor and turns on the heater.
May 01, 2016 | Paragon 8145-20 Defrost Timer
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Timer doesn't work
If you are saying the timer does not advance then it is probably a bad timer. However you may have another problem if it is just the automatic dry cycle that doesn't work. Most timers have a time cycle with minutes. If that works but the other auto cycles do not work, then one of the temperature sensors is not working. If the time cycle doesn't advance at all then the drive motor on the timer is bad. Complete timer needs replaced.
Jun 10, 2014 | General Electric DHDSR46GGWW Gas Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
The timer on my dryer does not work.
Hi, If the dry is heating and neither the automatic or the time cycle will advance, you will need to replace the timer. You can test the timer by removing the rear panle and locate the 2 black wires on the timer motor. While the dryer is running, check and see if there is 120V going where the black wires attach to the timer contacts.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag PYE2300AY Electric Dryer
TIMER PROBLEMS
Inside the timer there are a set of contacts which supply the timer with the voltage to run it, plus all the other loads
Over a period of time the contacts get weak with the heat that is built up in them while the washer is running (Especially if you run high temperature washes and the heater is on a lot)
The contacts then burn on the two surfaces that meet and it become pitted.
Repeatedly switching on and off causes the two surfaces to meet occasionally and you will get a circuit
No way out other than a new timer.
Jun 02, 2009 | Washing Machines
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Electric Dryer..Timer runs backwards only sometimes.
Probablyl the timer motor. Synchonosous motors that run these timers have a internal part that insure they always start the same direction.
Oct 10, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
220 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
