Question about Nokia 3110 Cellular Phone
In task bar cell phone icon displayed by X mark
NOKIA PC SUITE loaded.cell phone not recognised by data cable in PC. The connection not established for reasons not known. Every time in cell it is displaying "USB Data connected select mode" The cable used is DKE-2
    President:
  • Nokia Master
  • 511 Answers
Check the compatible usb chord for ur mobile DAU-9P FBUS
Posted on Sep 05, 2009
How to reformat nokia 5130 c-2 with the security keyguard forgotten
Follow this procedure to generate your security code.This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.3.Extract [ANT] Simple ] and run Simple.exe located in the folder4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.5.After you've connected your phone, Click "Read Info"6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below7. Nowclick on the SERVICE tab and click on GET button under USER CODE8. Your security code should now be displayed on the right side of the application window. After all format it by selecting "Restore All" from your phone setting.Thanks For visiting Fixya
Feb 27, 2012 | Nokia 5130 Cellular Phone
How can i update my nokia 3230
you can update it by using nokia pc suite installed in your computer with internet connection .........first install pc suite in computer->keep internet connection active->connect phone via data cable -> click on software update icon in pc suite->check for updates->then install it.
Sep 26, 2011 | Nokia 3230 Cellular Phone
Sir thanks for prompt reply sir, i have done all the procedure suggested by you and other sites suggestions but i am unable to connect my phone for internet via pc. i can connect the phone for computer...
You can do it very easily...just follow the steps:-
  1. Go "http://europe.nokia.com/support/download-software/pc-suites/compatibility-and-download" or click here to go to download page of nokia pc suite and download the pc suite.
  2. Install the pc suite onto your system
  3. now connect your phone using data cable
  4. The pc suite will automatically detect your phone
  5. now use "connect to internet" option in nokia pc suite.
  6. select the configure option and select the provider from drop down list.
  7. If your network provider is not listed then simply click "Configure connection manually" and enter the APN only and leave user name and password blank.
  8. you can get the apn from your customer care.Example....for airtel--airtelgprs.com, reliance gsm-- rcomnet, for docomo--tata.docomo.internet
  9. now click the connect icon
  10. Enjoy...you are connected to internet.
hope this will help........cheers:)
Sep 25, 2010 | Nokia 6070 Cellular Phone
My laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
Oct 14, 2009 | Nokia N97 Cell Phone
Problem in connecting nokia n72 with pc..
pc suite install after n72 sofware insert cd rom now data cable conected phone to pc find new hjadware plse search install the driver file, two times try it
Jul 10, 2009 | Nokia N72 Cellular Phone
Nokia 6070 PC Connectivity !!!
there is nothing you can do appart from sening it back to the company you bought it from or sent it to nokia for rapairs
thanks
and please rate my help
Apr 20, 2009 | Nokia Cell Phones
USB
Install PC Suite -
If not Done -
Check Settings From Phone - USB Device > Select Data Transfer or PC Suite -
Or Format ur Mobile n Check From PC if Connected -
IF Not Connected CHeck My Computer Properties -
Then go to Hardware > Device Manager > See the Device is there Connected or Not -
Jan 14, 2009 | Nokia 3110 Cellular Phone
Nokia pc suite do not recognise dku50 data cable
after you have installed nokia pc suite in your computer plug the data cable and restart your computer. it should automatically detect. if not switch off and on your phone along with the cable connected. if still not detected the you have bought the wrong data cable
Dec 19, 2008 | Nokia 6220 Cellular Phone
Problem connecting my any mobile through data cable to my pc
I have a Nokia 2630 with Data Cable but the Nokia suite and my PC will not reconise it. Is the problem at all due to some configeration within the phone as it will not recognise my password
Nov 05, 2008 | Nokia 2600
CA-42 cable connection via nokia PC Suite
Yes
I have experienced this problem. What you need to do is plug the usb cable into the computer before switching the computer. Make sure you don't plug the other end into the mobile phone yet.
Once the machine boots up. If you've installed nokia pc suite. It an icon will appear in the taskbar. Click on it can't remember whether its right or left click, but you need to select manage connections. Now if you are using a genuine nokia data cable you shouldn't have problems but if it isn't then you need to uncheck the usb options and check the option called 'serial'. Once you've done this a button called properties or settings or configure which is greyed out should become active. Then from the drop down box you will have various options eg. com1, com2, com3. What normally happens is when you don't have the cable plugged into the usb port only com1 will be displayed. But when the usb cable is plugged in com 3 or com 4 will appear. So you select com 3 or com 4, then OK. Wait for a few seconds then connect you other end of the usb cable to your mobile and it should recognise it after a few seconds.
Nov 16, 2007 | Nokia 3220
Nokia 3110 Cellular Phone Logo
93 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
