Question about Malber P25 Front Load Washer
Malber P25 washing machine - "on" button won't stay on
All of a sudden we are having a weird problem with our Malber P25 washer. When you press the "on" button in, the indicator light will come on briefly and then the button will immediately pop back out. There don't appear to be any issues with the door latch, which I've read is a common cause of problems with this machine. The machine still works fine - if we tape the button down in the "on" position then it will run through a whole cycle, it's just annoying and a little bit disconcerting.
Any ideas?
Manual for p25 malber
www.manualsonline.com
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 19, 2016 | Malber Washing Machines
P25 door is broken. i need to find a replacement, new door.
I have a P25 door I can sell you. If you need only a part of it, like the outer white plastic "cover" ring, I could provide only that.
If you'd feel better about it, we could do this thru eBay (and you could use their escrow). Otherwise, we'll figure out shipping costs (~$15) and you can mail me a check. I'd like $40 for the door.
Please call me, at 703-851-6536
Feb 20, 2014 | Malber P25 Front Load Washer
Water leaks on floor from my p25 washer.
This is a common problem with Malber. On the lower right hand corner, there's a door with a lint filter. This filter needs to be cleaned on a regular basis. Be careful when removing the filter. It has a large rubber gasket that expands when it's installed and tightened and will offer some resistance when removing. When the filter becomes clogged, water backs up and forces it's way out through the filter.
Aug 31, 2011 | Malber P25 Front Load Washer
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
I pet the new machine on quick cycle it takes more then 1 1/2 hrs styed forever on spin then i had to unplug it. also shakes uncontrollably
You will need to make sure it is level. With the machine off rotate the plugs till the washing machine is level. If that doesn't work, you will need vibratins pads under the feet to stop the vibration and allow it to cycle normally.
Aug 16, 2010 | Malber P25 Front Load Washer
After 3 years spin cycle has become almost
1st the machine has to be completely level--also take off the top--there should be two springs at the top and there are also shocks at the bottom--make sure none hav come offf
Oct 27, 2009 | Malber P25 Front Load Washer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Rubber piece
If you mean in the bottom of the gasket between the drum and the door the hole is to allow water to drain from the gasket to prevent standing water which will smell .
Aug 08, 2008 | Malber P25 Front Load Washer
TD700 malber front load
I'm not familiar with that particular brand, but it looks like a eurotech, and we sell those pulleys by the truckload. They are made of a similar material and break if you look at them funny. You may however, check that the inner tub does not move up and down if you reach inside the wash area and push up on the inner tub. If it does, you have bearing problems and are going to need some serious work, otherwise replace the pulley and it should be fine. Hope this helps!
Oct 20, 2006 | Malber P25 Front Load Washer
Malber P25 Front Load Washer Logo
116 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
