Question about Protron PLTV3250 32 in. LCD Television
Built in tuner not working since digital transition
I use an antena (roof top always picked great analog signals). Since the transition to digital signals I cannot pick channels that have already converted to digital without the help of a converter box. I was told when I purchased this TV in 2007 that it would pick up digital signals when the transition occurs, because it has a built in tuner within. I have read the manual several times and have tried to rescan to pick up the digital channels with no success. Therefore, I connect the converter box and I can get all the digital channels. This stinks because I have to have the converter box connected which means another remote, more wires, and now I will have to purchase another converter box for my old TV I know needed a converter box. I have tried to reach tech support number but it is not available. Any advice is appreciated.
  • Anonymous Mar 18, 2014
    TV will not pick up channel signal
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
Posted on Dec 19, 2009
  • 1tommy3 Dec 19, 2009
    This Protron PLTV3250 does indeed have a Digital tuner for use with an over the air antenna. You need to select DTV by pushing source on the remote. You are probably pushing source and selecting TV and this is for the analog input. If you select DTV from the source menu you can then press Menu on the remote and you will see a totally different user menu that you are probably not used to seeing. From this menu you can then so a channel scan and set up some different other options. I do not know if you figured this out by now but you certainly do not have to be using a seperate digital converter box with this TV. The digital tuner works great and the picture is beautiful. Please post back if or when you get this message. I hope this helps you. Tom
  • 24 Answers
Your TV must not have an ATSC tuner which is what you need to pick up over the air TV broadcast, so yes you do need a converter box. Someone lied to you, or most likely didn't really understand the difference between digital and HD-ready TVs: http://www.ezdigitaltv.com/HDTV_vs_HDTV-Ready.html
Posted on Jul 20, 2009
  • 22 Answers
Let me guess, you bought the tv at a big box electronic retailer? You were taken, it doesn't have a digital tuner built in, just an analog tuner. They should have told you this but of course you wouldn't have bought the TV. This was a way to sell LCD TVs at a cheaper price. All TV built this year have to have the digital tuner built in. You will have to use the converter box to pick up the digital signal, sorry.
Posted on Jun 02, 2009
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
Is my rca f27442 tv digital compatible?
Sorry no.All CRT(tube tvs) are analog tv.It all digital now,must have Digitial converter box and a roof or digital antena to get the analog tv to get the free DTV digital signal.Or u must cable tv.Only LCD tvs have the digital tuner insidide to pick up the free DTV digital signal without the converter box.
Sep 02, 2010 | RCA F27442 27" TV
Only picking up one digital channel
digital air signals are weak and fussy. They are easily lost by having trees or large buildings in the way too.
The best thing to do is install a long range roof top antenna and re program the set. Be sure to aim the antenna correctly. if you cannot use a roof top antenna you can try the indoor digital antennas,but less likely to work consistently
Jun 02, 2010 | Toshiba 40RV525U 40 in. LCD TV
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
DURABRAND TV MODEL DU 1901
Very easy to find out just plug it in.Have an antena,get picture ur tv work with digital,their no more analog signal out there.
Dec 16, 2009 | Durabrand DU1901 TV
Digital picture freezes for split second every now and again
U have Cable,Satalite,or Teleticom Siginals ur incoming signals 99.999%.Digital antena about 95%.Roof antena about 90%.Indoor Analog antena about 89%.Yes the signals is varies u will have freezes,not ur tv
Oct 15, 2009 | Televison & Video
My Vizio VW 26L loses all the digital channels when it is turned off. It works fine after a channel scan, but when it is off then back on there are only analog channel available. Bad tuner?
Tries different antena like a roof antena,or digital antena get better amplication input for receptions,still have signal not ur DTV tuner.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Feb 06, 2008 | Televison & Video
Protron PLTV3250 32 in. LCD Television Logo
975 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
