Question about Refrigerators
My Whirlpool fridge, a smaller model (24" wide, 22" deep, 61" high) was bought in late 2005. It has been moved a couple of times. It is now in a basement but plugged into 3-pronged outlet. It had to be moved across the room and an appliance extension cord used because its own cord wouldn't reach the outlet. But the problem has been and still is since it's been here that the bottom part doesn't keep the food cold at all, and the freezer does make ice cubes but the ice cream is soft and the frozen vegetables are barely frozen, and other things that should be hard (frozen) are not. Is this a major problem? We have tried adjusting the temperature, putting it almost to maximum in the freezer (which seems to help) but the bottom part, which we also turned practically to maximum hasn't changed at all.
  • 15,935 Answers
If the freezer was tipped on its side to move, and you plugged it in before waiting for the refrigerant to settle - your compressor may have been saturated by refrigerant.
Normally - 12 hours is recommended for refrigerant to settle in the compressor after moving a refrigerator.
The only way to repair is to have the system flushed - cleaned - and refilled - however it may be cheaper to buy a new basic unit.
The labor, refrigerant and cleaning will run approximately $200.
Another thing to check is the evaporator fan. It moves the air around in the freezer for an even freeze. It is a coil and fan hidden behind a panel in the freezer. Since the ice stays frozen... i would suggest searching for the evap. coil and making sure it is not (1) frozen up, or (2) fan not working.
If you use the "Continue with this expert" option and reply with the model # of the unit - I can help you further with parts ordering and additional troubleshooting.
Thanks for using FixYa!!
Posted on May 27, 2009
I need to know the specs for whirlpool rs630pxk
Do you need the size of the RS630PXK range? The range is 30" wide, 31 7/8" high and 22 3/4" deep. The installation opening needs to be larger to allow for air circulation around the range. It needs 120V AC power. The specifications for the size and the installation space size is given in the installation guide. Whirlpool has the guide on their product support page. The direct link to the installation guide is http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20311433.pdf . All of the documentation can be found by searching on the model number starting here: http://www.whirlpool.com/manuals/ .
I hope this helps.
Sep 30, 2015 | Whirlpool Stove / Oven / Range Cooktop -...
Whirlpool dp1040xtx flashing code 61 and 66. 61 flashed a couple times. What's wrong?
F6E1 - Water is not present in the machine when it should be.
Could be: inlet hose filter clogged, blocked holes on spray arms, dishes not loaded according to manual, water tap closed or water pressure too low, drain hose placed incorrectly, DW filters clogged, check dispenser (missing dispenser gasket, improper detergent), check water indicator (OWI or VWI) depending of model DW, check connections beetwen OWI (optical water indicator) and CB (control board), main motor, wiring, control board.
Check the foam level in the appliance. Depending what kind of detergent was used. Was the foam level too high?
Comment: Washing tabs combined with short washing cycles can produce too high foam level.
Dado
Jun 17, 2015 | Whirlpool Dishwashers
Trying to find a date of manufacturing for my coke fridge model # CGD-C serial # 338540
It to is a dry cooler with two double lids and a single external cap catcher. Casters where available to aid in moving coolers such as the CGD-C.
SPECIFICATIONS:Vending Capacity: 288 Bottles, 12 CasesPrecool Capacity: N/ADimensions: 36 1/4" high, 45 1/8" wide, 28 7/16" deepWeight: 324 lbs.Production Dates: Late 1960's
Aug 04, 2013 | Computers & Internet
Which is the exactly dishwasher dimensions
Hello giov..... the dimensions of the whirlpool DU930 require an opening that is 24 inches wide x 24 inches deep by 34 inches high.
Here is the manual showing these and many other measurements for this machine
http://www.managemylife.com/mmh/installation_guides/3874/WHIRLPOOL-Dishwasher-L0409637?brand_name_search=DU930PWWQ0+WHIRLPOOL
Joe
Thanks for choosing Fixya!
Mar 09, 2011 | Whirlpool DU930 Built-in Dishwasher
Noticed lately couple times.turn key off and seems to keep runnin
You mean something called "Run On", or "Dieseling"?
If so, your idle RPM might be too high.
May 27, 2010 | 2005 Yamaha Road Star Silverado
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have a whirlpool multiflow 380lt fridge i have broken some shelving i need the egg guard and crisper box where could i get these parts i live at st marys sydney nsw
Try contacting Stokes here:
Stokes (Australasia) Limited: Stokes Appliance Parts
24 Palmerston Rd West Ringwood, Victoria 3134 Australia
ACN: 24 004 554 929
Tel: +61-3-9845-8300
Fax: +61-3-9874-1077
E-mail: info@stokes-aus.com.au
Or contact Whirpool:
Whirlpool Service - Parts Price List
call Whirlpool Service on 1300 363344 (Australia) or 0800 442584 (NZ)
Sep 09, 2008 | Whirlpool Refrigerators
Funny smell from RS2630SH
Dear friend,
ngfam at you service! happy to assist!
Whirlpool sells odor stoppers for your fridge!
And keep a open box of baking soda on the door always!
HERE IS THE WHIRLPOOL SITE BELOW
http://www.whirlpool.com/catalog/
accessory_category.jsp?parentCategoryId=
323&categoryId=370
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
