Question about Kenmore Elite 45986 Front Load Washer
HE5 frontload washer error f11
Starts to run than shuts down with f11 error. Less than 2 years old
  • 59 Answers
F11 error code indicates a communication problem. The communication between the Central control board and the Motor control board cannot be sent correctly.
Potential causes:
1. Loose connections between the motor control board and the machine control board, or at
motor
2. Machine control board failure
3. Motor control board failure
4. Motor failure
5. Door lock failure
If this answers your problem, please rate my answer.
Thanks,
David
Posted on May 27, 2009
I have an F11 error code on my maytag frontload washer?
It sounds like a control unit has burned out. There is a computer that speaks to the motor to tell it what to do. If you reset it and a part is bad the computer will still recognize the problem and thus resend error message.
May 04, 2014 | Maytag Washing Machines
Whirlpool Duet F11
Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Getting F11 code r8ght after starting,then flashes and stops
usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
443 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
