Question about Xerox Phaser 8200DP Thermal Printer
Powering Up My Xerox Phaser 8200DP
My phaser 8200DP stopped right in the middle of a print job, I shut the printer off and removed the half printed paper. I powered back up and the Xerox come up in the display and just froze. I shut it back of and restarted the printer nothing come back on the display but it looked like it was trying to light back up but never would. I tried the number 1 dip switch but nothing I tried the reset dip switch and nothing on it either. It just looks like its trying to start up but it doesn't. Sure was a great working printer will hate to lose it.
Thanks
Richard S.
    President:
  • 2,072 Answers
I assume no codes are coming up after leaving it on for a long time.
Most likely problem is the electronics module.
With the price of it you could buy 2 new dry ink phaser printers.
But what you are describing sounds like an electronics module issue.
Posted on May 27, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Stop Printing
Hi and thank you for using fixya:
To stop your printer from printing while printing press stop or cancel in your printer control center. Also you can click stop or pause on your computer print dialog box,
1-right click on top of the printer
2- click pause on current job printing
good luck!!
Apr 08, 2010 | HP PSC 1350 All-In-One Thermal Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
5500 xerox phaser
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Oct 30, 2008 | Xerox Phaser 8500N Printer
Paper trays
1. Remove the print driver on the PC if this is a local shared printer.
2. Re-share the printer will cause the driver to re-install.
Now the next way to fix issues like this too go to step 3, but only if step 1 and 2 does the same effect.
3. Turn it off and unplug it for 30 seconds.. Now plugin the power. Press and hold the power button for 30 seconds to force a reset back to factory defaults.
Still it sounds like a configuration error or bad network driver if this printer is on the network.
Jul 23, 2008 | Xerox Phaser 7700DN Laser Printer
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
Xerox Phaser 8200DP Thermal Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
