Question about Sub-Zero 690 Side by Side Refrigerator
My side by side sub zero fridge has frost building up on the back wall of the refridger ator side it is about 1/2 inch thick
I had the exact same problem. It was the evaporator coil had a leak. The coil is covered under waranty the labor is not! It was $295.00 labor and $48.00 for the gas recharge.total $343.00. Hope this helps! Yes, the price was high but it fixed the problem.
Part # was 4204420
Ed
Posted on Jun 11, 2009
    Problem Solver:
  • 7 Answers
Sub Zero evaporators are known to leak - I would call Sub Zero and demand they cover all the costs.
Posted on Dec 12, 2009
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
My sub-zero 245 has a build up of frost behind the ice maker bucket, the vent has about one inch build up of frost . The ice cubes are almost clear?
HI.RON.i think this has to be in stages.1-defrost evvvvverything first 2-turn off water supply.if this cure the problem the the fault lies on inlet valve(leakig over)try.good luck
Jun 19, 2012 | Sub-Zero 245
Sub Zero Model 550 (1992) freezer drawer doesn't seal
the drawer need to be adjusted so that it will close.. with a air leak you will have frost build up around the drawer...there are drawer closers on the back of the rails... it may be broken or just pushed the wrong way...when the freezer is cold it should make that sucking sound and be hard to open ... hope it helps
Sep 19, 2009 | Refrigerators
Ice on back wall of fridge
The ice forming on the back wall of your sub zero indicates that you have a part failure. I don't recall exactly what the part is but as soon as you mention your symptoms to a sub zero repairman he'll know your problem. It's an easy fix. Everything comes out of the fridge, takes the inside back wall off and replaces the part. Not an inexpensive repair, however the part is guaranteed for 5 years so you may have an opportunity to have it replaced under warranty as I did.
Sep 07, 2009 | Sub-Zero 632 / S
I have a Sub Zero 201 F, that ices up around the freon line.
It sounds like your fridge has had some servicing done on it and has been over charged with freon and needs to be decanterred.Kind Regards.
Jul 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Mar 14, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
My Sub-Zero 611/O is not cooling enough. The temp is 0 in the freezer and 46 in the fridge. I vacuumed very well the condenser. I can't tell which compressor is running. There are two, one larger than the...
More than likely the fan inside the back of the unit freezer compartment is not working and causing the freezer to freeze up.need to pull pannel off inside back of freezer and replace fan
Jan 14, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
607 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
